Aluminum retainers worth using?
Old Jun 5, 2005 | 03:54 PM
RedEj8's Avatar
Default Aluminum retainers worth using?
Is there any downside to using aluminum retainers instead of titanium? Ive heard Ti retainers are wear items for race cars but i figure aluminum retainers can't be that much more heavier than Ti retainers. I plan to use RM gen2 springs so would aluminum retainers be alright or should i just go with Titanium?
Old Jun 5, 2005 | 04:32 PM
NJIN BUILDR's Avatar
Default Re: Aluminum retainers worth using? (reddohcvtec)
https://honda-tech.com/zerothread?id=682794
There is a post near the bottom from RM himself (Rocket).
Glenn
Old Jun 5, 2005 | 06:42 PM
C2Imports's Avatar
Default Re: Aluminum retainers worth using? (NJIN BUILDR)
my motor blew up with aluminum retainers they mushroomed around 8800 rpms - dont use them
Old Jun 5, 2005 | 07:04 PM
cpforyou's Avatar
Default Re: Aluminum retainers worth using? (towsondragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by towsondragcrx &raquo;</TD></TR><TR><TD CLASS="quote">my motor blew up with aluminum retainers they mushroomed around 8800 rpms - dont use them </TD></TR></TABLE>
I used to have a built fully built JG Motor. After awhile it failed because of the JG Aluminum Retainrts.
Old Jun 5, 2005 | 07:33 PM
earl's Avatar
Default Re: Aluminum retainers worth using? (cpforyou)
Aluminum retainers tend to open up and allow the keepers and valve to pull thru them. Bad news for your motor.
Old Jun 5, 2005 | 09:28 PM
k24em2's Avatar
Default Re: Aluminum retainers worth using? (earl)
Just a quick FYI, titanium is heavier than aluminum.
Old Jun 6, 2005 | 12:40 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Our springs and retainers use a snap in design, which drastically reduces wear on the retainers. It also means that our springs and retainers are designed to work together, and shouldn't be mixed with other products.
Old Jun 6, 2005 | 01:09 AM
rjay8604's Avatar
Default Re: Aluminum retainers worth using? (rochesterricer)
I was always really uneasy about aluminum retainers. Maybe and exotic alloy, aluminum just doesn't have the desired properties for something like a retainer, honestly it even impresses me that titanium is worthy of the task. The retainer has such a critical role. I wonder what is the valve keeper/lock angle for our honda's. I wonder if any of the companies have experimented with different angles.
Old Jun 6, 2005 | 09:47 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">Our springs and retainers use a snap in design, which drastically reduces wear on the retainers. It also means that our springs and retainers are designed to work together, and shouldn't be mixed with other products.</TD></TR></TABLE>This is very true and a good point. The spring and retainer must fit together tightly or the titanium will flake off of the retainer as the spring moves around. This is what I like about the SuperTech design..a very tight fit also.
Old Jun 6, 2005 | 10:09 AM
Rocket's Avatar
The only time we would reccommend Al retainers would be for our competition. If they don't know better then too bad for them.
One needs do research regarding limited fatigue life of aluminun. There is a very good reason why lifetime hours of usage are recorded for airplanes and helicopters and once a specified limit is reached the aircraft is retired.
Modified by Rocket at 7:23 PM 6/6/2005
Old Jun 6, 2005 | 10:25 AM
f@sth@tch89's Avatar
Default Re: Aluminum retainers worth using? (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">The only time we would reccommend Al retainers would be for our competition. If they don't know better then too bad for them.
Modified by Rocket at 7:23 PM 6/6/2005</TD></TR></TABLE>
lol
Old Jun 6, 2005 | 01:32 PM
RedEj8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=682794
Glenn</TD></TR></TABLE>
Thanks..I searched Everything and somehow couldnt find anything worthwhile
Old Jun 6, 2005 | 01:36 PM
RedEj8's Avatar
I'll be going with the RM gen2 springs and retainers. Thanks for the info peoples!!
dc4teg95
Nov 16, 2007 12:01 PM
ATS*Mark
40
Sep 10, 2007 07:38 AM
ranta18
Sep 28, 2004 02:41 PM
hybridEj6
12
Jul 2, 2004 08:37 PM
Mover
Jul 8, 2003 09:21 AM
