ITR Intake fit gsr?....
Old Feb 8, 2002 | 09:06 PM
GsrSdn's Avatar
Default ITR Intake fit gsr?....
Just wanted to know if an AEM CAI from an itr would fit my gsr?
Old Feb 8, 2002 | 09:07 PM
StinkyTofu's Avatar
Default Re: ITR Intake fit gsr?.... (GsrSdn)
if you have the stock manifold then no, if you have the skunk2 or modified ITR intake manifold then yes. Your throttle body is slightly smaller but you can make it fit if you tighten the hose clamps enough.
Old Feb 9, 2002 | 05:41 AM
1GreyTeg's Avatar
No, I mean it will fit if you clamp it on but, it won't fit correctly.
The GSR TB is: 60mm
The ITR TB is: 62mm
Clamping on the ITR intake may even produce unwanted variables with airflow actually hampering velocity. Get the one that is made for your car.
Oh and thinking a larger intake pipe will flow more air is intriguing but, only if it is specifically designed for that application. The wrong intake might even produce negative results, such as loss of power...
Good luck,
A.
Old Feb 9, 2002 | 06:44 AM
Benjamin Tang's Avatar
Default Re: ITR Intake fit gsr?.... (1GreyTeg)
i'm thinking no. i'm trying to remember my old b18c1 teg and i recall that the throttle bodies don't sit on the same vertical level (i think the gsr one sits lower)...
Old Feb 9, 2002 | 08:59 AM
GsrSdn's Avatar
cool thanks , just picked up the gsr and a buddy of mine has a cai from an itr laying around so i was just gona use it for now , i guess i'll just find one for the gsr.
BG-Teg
Mar 16, 2007 02:42 PM
be18see1
Sep 12, 2006 05:20 PM
JMD
Jan 26, 2004 04:40 PM
acuraqc
Jan 21, 2004 12:34 PM
douglas_be
Nov 30, 2003 09:48 AM
