6'th gen A/C
My A/C worked great last year, so like 2 months ago My condenser went out and the dealership replaced it under warranty
My question is to all the g'th gens out there does your a/c blow cold all the time? My A/C kind of comes and goes it gets cold then it kind of warms up and so on. It doesn't matter what engine speed or anything. I Drive a ford F-150 at work sometimes and that a/c is so cold I can keep my beer cold in the back. I just dont want to call the dealership and complain unless I know its not normal. thanks
have them check it over and make sure that the pressure is not too high from an overcharge. If it is overcharged, a high pressure cut out switch will kick in and your compressor will turn off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">have them check it over and make sure that the pressure is not too high from an overcharge. If it is overcharged, a high pressure cut out switch will kick in and your compressor will turn off.</TD></TR></TABLE>
Ok thanks, I was pretty sure there was a problem because I dont remeber itl like this last year.
George Knighton
24
Jun 26, 2006 06:13 PM
