LSD Tranny problems.
Old Jun 5, 2005 | 02:24 PM
xpsonic's Avatar
Default LSD Tranny problems.
I installed my tranny w/ Quaife LSD that I got off a fellow HT member and it seems within the diff there are like 2 washers, I wanted to know if other members with Quaife on their D-series have 2 washers that are supposed to be in between the 2 axles.
The reason why I ask is when I put my axles in they dont quite fit all the way and leak MTF slowly. Is this because I need different axles? Are there any other axles for D-series? This is a CRX Si Trans and I have those axles. Please let me know if anyone can help me out.. I'll try to get pics asap.
Old Jun 5, 2005 | 02:44 PM
xpsonic's Avatar
Default Re: LSD Tranny problems.
nobody knows?
Old Jun 6, 2005 | 12:51 PM
tgreaves's Avatar
Default Re: LSD Tranny problems. (xpsonic)
Bump for you.. If anyone knows why this would happen please post it in here.. I sold him this tranny and Quaife and I like to make sure people who deal with me are happy with their stuff..
I was using 93 civic dx axles with this tranny in my crx before if that makes a difference.. Im not sure what you mean when you say washers inbetween the axles..
Here is a pic of that tranny and Quaife at my house a while ago, is what your talking about in the pic?
Old Jun 6, 2005 | 01:57 PM
*Boostwerks*'s Avatar
Those arn't washers.
They are the ends of the gears that the axles rest against.
If your tranny is leaking fluid at the axle, then your tranny seals need replacing.
Old Jun 6, 2005 | 04:26 PM
xpsonic's Avatar
Default Re: (Bryson)
nah the axles just dont get close enough to seal it correctly. theres about | | that much space until the actual whole axle foot can be flush, i tried using a rubber mallet and hitting it but it doesnt want to budge, I will try again...thanks for the input tho.
Old Jun 7, 2005 | 05:44 AM
tgreaves's Avatar
Default Re: (xpsonic)
Are both of the axles not going in the same distance? I wonder if maybe something small is sitting in there or something like that, maybe a piece of packaging foam or something, you never know..
Old Jun 7, 2005 | 09:03 AM
goforbroke's Avatar
MEAT PATTY
Default Re: (tgreaves)
roadracing and autox forum might help more. Everyone seems to be running a lsd in that forum.
Old Jun 7, 2005 | 09:05 AM
civicflow's Avatar
Default Re: (goforbroke)
Try to pinch in the ring clips at the tranny side of the axle a little. I had to do that on my friends to get his in. Something to try.
Old Jun 7, 2005 | 09:14 AM
Default Re: (civicflow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflow &raquo;</TD></TR><TR><TD CLASS="quote">Try to pinch in the ring clips at the tranny side of the axle a little. I had to do that on my friends to get his in. Something to try.</TD></TR></TABLE>
If the retaining rings are expanded too much, it will make it very hard to seat the axle.
Old Jun 7, 2005 | 09:42 AM
xpsonic's Avatar
ya well i thought that was the prob too, so what i did was took the ring off all together and tried to put the axle in w/o it to see if i could get it flush but it doesnt go. is it cause i need axles with longer grooves? like zc shafts?
Old Jun 7, 2005 | 09:46 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xpsonic &raquo;</TD></TR><TR><TD CLASS="quote">ya well i thought that was the prob too, so what i did was took the ring off all together and tried to put the axle in w/o it to see if i could get it flush but it doesnt go. is it cause i need axles with longer grooves? like zc shafts? </TD></TR></TABLE>
Ill measure the grooves on mine tonight..
Old Jun 12, 2005 | 12:55 PM
xpsonic's Avatar
Default .
any measurements yet?
Old Nov 1, 2005 | 10:11 AM
xpsonic's Avatar
Default .
i still havent got it done, now i have a week to figure it out. help!
Old Nov 1, 2005 | 12:40 PM
EFSiR's Avatar
I'd question the application of that diff. Hope you got one for the wright trany.
Old Nov 1, 2005 | 09:03 PM
xpsonic's Avatar
wright? im sure it is, well the seller told it was. and it looks so.
Ldo
Sep 11, 2008 06:06 PM
JDM H22
Oct 10, 2007 07:23 AM
civichatch52687
Oct 12, 2004 05:30 PM
chackoperformance
Mar 21, 2004 11:16 PM
drewlee
Oct 2, 2003 07:48 PM
