3.504's polishing tips:
Old Jun 5, 2005 | 01:34 PM
3.504's Avatar
Default 3.504's polishing tips:
welcome to my post on how to hand polish. first i'm going to introduce you to what you'll need:
in the picture is a jug of metal safe paint stripper, sand paper (you'll need an assortment), a small can of "mothers mag and aluminum polish," and an un-shiney piece of metal.
the sand paper i use ranges from 80 grit to 400 grit. some people go higher, but i like 400 because a machine such as a buffing wheel can remove it clean and why spend the extra time doing finer grits?
i also recommend you get a fine towel or cloth for rubbing the compound in. such as terry cloth or cheese cloth.
you'll need a large tub or go outside and use your hose when rinsing off the paint stripper, its really messy. just follow the directions on the paint stripper can.
plenty of paper towels, and a safe work area. i also suggest having plenty of time and plenty of cigarettes plus a case of beverages of your choice .
here we go:
a little bit of stripping
some pics of 80 grit (removes the deep blemishes, after you remove the deep stuff the rest of the grits go really fast. this is the main part of your work load.)
after you've gone through the sanding procedure, you start working in the polish compound. i like to use the really fine/soft cloth for this. just work in a dime sized amount until it turns black, turns hard, then wipes itself away without changing spots on the towel. in other words, dont clean away black polish with a clean part of the towel, just keep rubbing on the same part of the towel.
after this, you have successfully hand polished a piece of metal.
to you
this isn't the cleanest polish, but its damn close and you dont have to use any special machinary, just your hands. if you want that crazy chrome look i suggest investing in a jewelers style polishing wheel and getting all of the rouges required.
good luck.
Modified by 3.504 at 6:38 PM 6/26/2005
Old Jun 5, 2005 | 01:52 PM
PostMASTER-S27's Avatar
Default Re: 3.504's polishing tips: (3.504)
Old Jun 5, 2005 | 02:07 PM
DnB TeK's Avatar
sweet you can do my valve cover now......
Old Jun 5, 2005 | 02:11 PM
3.504's Avatar
Default Re: 3.504's polishing tips: (DnB TeK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DnB TeK &raquo;</TD></TR><TR><TD CLASS="quote">sweet you can do my valve cover now......</TD></TR></TABLE>
for $150.00 i'll do it
Old Jun 5, 2005 | 02:17 PM
MolecularIntegra's Avatar
Smoking while using paint stripper
Old Jun 5, 2005 | 02:23 PM
babietuan323's Avatar
Old Jun 5, 2005 | 02:35 PM
3.504's Avatar
Default Re: 3.504's polishing tips: (MolecularIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MolecularIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Smoking while using paint stripper </TD></TR></TABLE>
that was for picture purposes.
i mentioned in my instructions to use a safe work environment. i'd hope if someone was handling flamable material they'd be smart enough to not smoke around it.
Old Jun 5, 2005 | 02:36 PM
patastinky's Avatar
appreciate that !
Old Jun 5, 2005 | 02:38 PM
You also recommended having a lot of cigarettes. I know most people aren't that stupid but you never know. I'm just messing around.
Old Jun 5, 2005 | 02:41 PM
markwitdada9
Guest
Posts: n/a
Default Re: 3.504's polishing tips: (MugenRSX-S27)
Old Jun 26, 2005 | 02:41 PM
3.504's Avatar
Default Re: 3.504's polishing tips: (markwitdada9)
i did some more work on the valve cover, its almost done, just need to finish up the detailing paint work.
again, sorry about my 17 dollar walmart camara...
what do you guys think? ?
Old Jun 26, 2005 | 02:45 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
nice!
Old Jun 26, 2005 | 03:33 PM
intenseEK's Avatar
Default Re: (1 point 6)
looks good
Old Jun 26, 2005 | 03:38 PM
Squallie's Avatar
Default Re: (intenseEK)
wow!
Old Jun 26, 2005 | 04:00 PM
Diverse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intenseEK &raquo;</TD></TR><TR><TD CLASS="quote">looks good</TD></TR></TABLE>
Old Jun 26, 2005 | 04:25 PM
oemDC2's Avatar
Default Re: (Diverse)
cool..
Old Jun 26, 2005 | 04:36 PM
sloweg6's Avatar
Old Jun 26, 2005 | 04:37 PM
Seedc2's Avatar
nice
Old Jun 26, 2005 | 04:40 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: (sim shadeee)
Nice to see some hand polishing tips.
I know a motorcycle shop thats local that does all of their work by hand. They charge a GRIP, but their work is CRAZY!
Old Jun 26, 2005 | 04:45 PM
WhatThaFrig's Avatar
Default Re: (Ben Howard)
Nice! Hand polishing is a pain in the ***! But it looks damn good when you are done.
Old Jun 26, 2005 | 05:02 PM
3.504's Avatar
Default Re: (WhatThaFrig)
thanks for all the comments guys.
hopefully the guy im doin this cover for likes it too
Old Jun 26, 2005 | 05:11 PM
Stunna BEN's Avatar
Default Re: (3.504)
cant wait to see more of your work
Old Jun 26, 2005 | 05:40 PM
vart's Avatar
damn that looks nice, i might have to do that.
Old Jun 26, 2005 | 07:31 PM
plusONE jboy's Avatar
was a bitch hand polishing my radiator but well worth the time.
Old Jun 26, 2005 | 07:39 PM
Danger's Avatar
Default Re: (j boy)
i polished my distributer by hand ... well almost all by hand final step i did w/ a buffing wheel . came out nice though.. ill post a pic tomorrow .
nice write up
