mpfi pinouts?
my dual port harness falls apart each time i mess with it and it has been botched up quite a bit by the previous owner.
i want to go to a junkyard and pick up a crx si or hf harness and repin it for use in the dx body
anyone have a write up on how to do the mpfi swap this way or just give me input/links to do this project? my shop manuals have no wiring diagrams
I know this is going to sounds terrible but if you search in the archive CRX/EF forum you will find all the good info.
If you search for it you'll get your answer faster. Also up in the sticky is some GREAT info on this swap too.
Sticky --> https://honda-tech.com/zerothread?id=637661
If you search for it you'll get your answer faster. Also up in the sticky is some GREAT info on this swap too.Sticky --> https://honda-tech.com/zerothread?id=637661
i wish i had seen that earlier for some other stuff.
unfortuantly my harness is in very bad condition so i would like to get a newer harness to start with, my temperature plugs are torn up, reverse switch, and many others are already cut and spliced and is generally a mess.
i just need the engine harness pinout diagrams where they go into the car i have the ones at the ecu
http://www.fourthgenhatch.com , click on the tech section/how to's/MPFI and scroll down for a complete wire diagram of both DPFI and MPFI harnesses
Also you will need to use a DX harness for your car and just splice in the needed plugs for the injectors, distributor and resistor box if you want to go MPFI. So you should be looking for a good condition Dx harness, it will be much less of a headache than trying to get an SI or HF harness to work with your current rig.
that site is back up<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Floored »</TD></TR><TR><TD CLASS="quote">http://www.fourthgenhatch.com , </TD></TR></TABLE> <FONT COLOR="red"> ROCK ON </FONT>
THIS MIGHT HELP YOU
JUST DONT LOOK AT THE VTEC PINS ITS $ A OBD0 MPFI
A01-INJ1 fuel injector control # 1
A02-PG1 Ground
A03-INJ2 fuel injector control # 2
A04-PG2 Ground
A05-INJ3 fuel injector control # 3
A06-**
A07-INJ4 fuel injector control # 4
A08-VTS VTEC solenoid
A09-**
A10-**
A11-IACV from electronic air control valv
A12-FLR1 fuel pump control
A13-IGP1 power Input
A14-FLR2 fuel pump control
A15-IGP2 power Input
A16-**
A17-**
A18-**
B01-VBP Battery Backup
B02-**
B03-ACC a/c compressor clutch relay cont
B04-FANC
B05-VTM VTEC pressure switch
B06-MIL check engine warning light
B07-**
B08-ACS a/c on input
B09-**
B10-CYP P crank sensor (1)
B11-**
B12-CYP M crank sensor (2)
B13-**
B14-ALT alternator output signal
B15-**
B16-VSS VSS
B17-**
B18-**
B19-KS Knock sensor
B20-SCS ignition timing adjusting connec
C01-CKP P CYL sensor (1)
C02-CKP M CYL sensor (2)
C03-TDC P TDC sensor (1)
C04-TDC M TDC sensor (2)
C05-IAT intake air temperature sensor
C06-ECT coolant temperature sensor
C07-TPS throttle angle sensor
C08-O2S Dual O2 Sensor (JDM)
C09-PA atomosphere pressure sensor inpu
C10-BKSW brake light switch
C11-MIL ground
C12-SG2 TPS GND
C13-VCC1 TPS 5V
C14-SG1 MAP GND
C15-VCC2 MAP 5V
C16-O2S oxygen sensor
Modified by src-rider at 1:23 AM 6/23/2005
Modified by src-rider at 1:26 AM 6/23/2005
A02-PG1 Ground
A04-PG2 Ground
A06-**
A09-**
A10-**
A16-**
A17-**
A18-**
B02-**
B04-FANC
B07-**
B09-**
B11-**
B13-**
B15-**
B16-VSS VSS
B17-**
B18-**
B19-KS Knock sensor
C11-MIL ground
C12-SG2 TPS GND
C13-VCC1 TPS 5V
C14-SG1 MAP GND
C15-VCC2 MAP 5V
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_smallblockchevy »</TD></TR><TR><TD CLASS="quote">my dual port harness falls apart each time i mess with it and it has been botched up quite a bit by the previous owner.</TD></TR></TABLE>
Just let some professionals fix it.
http://www.rywire.com
I'll repair the whole thing for $160.
http://www.rywire.comI'll repair the whole thing for $160.
phamt2
Oct 6, 2004 04:31 PM
