cel codes, the same for all hondas?
are the cel code definitions the same for civics and accords? if i diagnos it myself with a paper clip, how do i know if its a PXXX type code?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duh blacksheep »</TD></TR><TR><TD CLASS="quote">how do i know if its a PXXX type code?</TD></TR></TABLE>
You only get the pxxxx codes using a scantool on OBD2 models. If you want to jump the service check connector or DLC for the codes, you have to count the CEL flashes.
but how do i know what the code means? are they the same as all civics? its a 2000 accord, i want to make sure its the same codes compared to the civic or if someone can tell me what all the codes for a 2000 accord are
if you got an "Autozone" in your area, they can use the OBD II scanner in the parking lot for free!!!
http://www.troublecodes.net/honda/
this site doesn't mentioned that u can access your 2000 model via paper clip tool; so I suggest getting it read via autozone for free...
here's the OBD II list:
http://www.troublecodes.net/honda/hondaobd2.shtml
duh blacksheep
Jun 5, 2005 03:47 PM
