Free beer if you tell me how to solve my problem.
wow my week is really sucking...for some reason all my lights (except: headlights, inside dome light and reverse light) will not turn on. parking, turn signal (except when in hazard mode)break lights dash lights..they all will not turn on..do i need a lighting relay or something else. if anybody can solve my problem i'll send the person that helped me solve the problem money (by paypal) to buy your favorite case of beer. sounds pretty fair to me.
only fuses are the hazard and the dome lights..but they are the only ones wroking..all the rest are dead..i checked every bulb there all good. i have no clue..i just know i need to car to drive tonight and i have no break lights..i called honda they told me to bring it up to let them look at it..55 bucks an hour to look for the problem..+85.00 to fix it, if its the relay....thats rape...
Check interior lighting fuse. If you recently installed a head unit or something, check your wiring on that. Remove the wiring harness for the radio and set it aside. Replace the interior lighting fuse. If it doesn't blow again, reinstall the head unit and see if it blows. If it does, your wiring was the problem. Recheck wiring.
There is an interior lighting fuse. I think it's on the driver's side kick panel. It's kind of a bitch to get to on my 4th gen, but just look around for a blown fuse and you'll find it. I'm pretty sure that's the one. I had that problem on my 4th gen when i screwed up my sound system wiring.
Yeah, be sure to check the fuse box under the hood and by the clutch pedal. I know you probably know where all your fuses are, but hey...
Kg cm2
Nov 10, 2004 07:21 PM
