Light Bulb blew..where to get a light bulb for 1 piece headlights. ( just stock ones nothing fancy)
Old Jun 5, 2005 | 12:53 AM
SiB16A's Avatar
Default Light Bulb blew..where to get a light bulb for 1 piece headlights. ( just stock ones nothing fancy)
My light bulb died on me. I need both h1 and h4. I was wondering where to buy them at. I don't need anything fancy. Just stock ones like the ones you would buy at honda for usdm headlights. I dont want that hyper white, hyper blue stuff. Just plain oem. Also i was wondering how to take off the light bulb. It's different and it is not like the usdm where you turn and pull out. All answeres are appreciated. Thanks.
Old Jun 5, 2005 | 08:52 AM
Cashis Lee's Avatar
Default Re: Light Bulb blew..where to get a light bulb for 1 piece headlights. (SiB16a)
Kragen/Autozone should have some OEM-style Sylvannias for about $10 a pop
Old Jun 5, 2005 | 10:14 AM
ken86's Avatar
try pep boys or strauss auto
Old Jun 5, 2005 | 11:01 AM
The Phil's Avatar
Default Re: (ken86)
Removing the bulb is pretty much self explanitory. Remove the black clip on the back of the rubber circular thingy. Pull the circular thingy out and set it aside. Don't set it on the engine or anything hot, because that would be dumb. Move the clip that holds the bulb in place out of the way, remove the bulb, replace with new bulb (being sure not to touch the bulb itself, only the metal base), and reinstall the clip. Replace the rubber circle, which should still be unmelted because you remembered to not put it on the engine. Replace the black connector for the bulb and you're done.
And in case you're wondering...yeah, I slightly melted one of those rubber things on my 1-pieces.
Old Jun 5, 2005 | 01:18 PM
SiB16A's Avatar
Default Re: (xthephilx)
Where can i get some real oem ones? Do you know? Are Sylvannias a good brand? thanks for anwsers. By the way xthephilx do you have a diagram of any sort to take off the light bulb step by step i dont really want to melt anything..also how do you adjust the light i have no idea how on the 1 pieces. usdm was just a screw you screw in and out.
Old Jun 5, 2005 | 02:17 PM
The Phil's Avatar
Default Re: (SiB16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16a &raquo;</TD></TR><TR><TD CLASS="quote">Where can i get some real oem ones? Do you know? Are Sylvannias a good brand? thanks for anwsers. By the way xthephilx do you have a diagram of any sort to take off the light bulb step by step i dont really want to melt anything..also how do you adjust the light i have no idea how on the 1 pieces. usdm was just a screw you screw in and out.</TD></TR></TABLE>
Sylvanias are good. You don't have to worry about melting anything unless you put the rubber part on top of something hot. Put it in your pocket or something instead. Other than that you'll be fine. It's pretty self explanitory. If you're still having problems i'll take a picture later.
Old Jun 5, 2005 | 05:34 PM
SiB16A's Avatar
cool you should take a pic.
Old Jun 5, 2005 | 06:49 PM
The Phil's Avatar
My camera is at work now. I'll take a picture after work tomorrow.
Old Jun 5, 2005 | 07:18 PM
krnfly2damoon's Avatar
pics!
noss88
Jun 6, 2007 01:07 AM
Ruben19
Nov 1, 2006 08:21 PM
Thunder Cat
Oct 31, 2005 11:14 AM
animated_life
Dec 27, 2003 12:03 PM
