ls vtec or b16a stroked
Old Jun 4, 2005 | 11:45 PM
1750cc's Avatar
Default ls vtec or b16a stroked
currently i have a b16a stroked to 1840 (81x89mm) running about 11.5:1 CR (flat top piston )...is it better to change my block to a b18b with ctr pistons? also, i've read that most of ls/vtec riders here change their rod bolts so arp. why is that? what's the problem with using oem bolts? thanks.
Old Jun 5, 2005 | 08:37 AM
Grand's Avatar
the oem bolts are to weak to rev that high they stretch and break you should also run arp main studs and headstuds
Old Jun 6, 2005 | 02:26 AM
1750cc's Avatar
Default Re: (LG_R32)
are the main studs of b18b and their bolts different with the ones in b16a? i rev my motor up to 9500 on the track...and so does my friends....we've never encountered such problems with the bolts...
cinder0159
Apr 16, 2011 07:10 PM
93preludes
Oct 21, 2005 12:58 PM
Weapon_R
Dec 13, 2004 09:23 PM
sikcrx80
Jan 8, 2004 04:46 PM
jboostedhatch
May 2, 2001 09:56 PM
