front turnsignals hard to see (jdm corners)
Old Jun 4, 2005 | 11:26 PM
LShatchie's Avatar
Default front turnsignals hard to see (jdm corners)
I took my car to inspection and one of the things it failed for was '' electrical problem with front turn signals'', and I asked what this ment because I knew for a fact that they worked, and I was just told that they dont work. So I go outside to take my car home, but first I check to see if they really dont work, turns out they do but they are very hard to see during the day. At night you can see them fine. I have JDM corners and they are so yellow I geuss its hard to see the light. I have the right bulb that supposed to be in there. So my question is have any of you ever had this problem with ur jdm corners, and how did u fix it ? get a higher wattage bulb ?
Old Jun 5, 2005 | 12:31 AM
d15bcoupe's Avatar
Default Re: front turnsignals hard to see (LShatchie)
go to certifit, buy 2 10$ stock corners. swap. inspect. swap.
Old Jun 5, 2005 | 12:53 AM
EL Vap133's Avatar
That's why I stuck with my USDM corners.
jetspeedz
Jul 14, 2009 08:14 PM
JDM-EJ1
Jan 6, 2005 07:20 PM
JDM-EJ1
Nov 5, 2004 08:11 PM
crxste
11
Oct 26, 2004 12:00 PM
kent
Apr 30, 2003 05:24 AM
