Idle Outa control!!! Any Ideas??? Thanks!
Old Jun 4, 2005 | 10:42 PM
slice125x's Avatar
Default Idle Outa control!!! Any Ideas??? Thanks!
95 civic d16z6-
engine idles very low (between 500-600 r's) when it gets up to temp or on very hot days.
I've had to advance the ignition timing pretty far just to get a decent idle at any temp. The problem here is my plugs have since turned white... so i know it's getting all the spark it needs. I can't leave it advanced like this too much longer or I'm going to run into more problems.
I've replaced the plugs (ngk), wires (magnecore 8.5), cap/rotor/dizi... and the ecm is throwing no codes. I've also looked over all the vacuum lines and everything looks to be finr there.
If anyone has any sugestions they would be greatly appriciated!
Thanks, Mike
Old Jun 4, 2005 | 10:44 PM
handa's Avatar
Default Re: Idle Outa control!!! Any Ideas??? Thanks! (slice125x)
it's not a good idea to adjust the idle screw, but did you try that?
Old Jun 4, 2005 | 10:50 PM
slice125x's Avatar
Default Re: Idle Outa control!!! Any Ideas??? Thanks! (handa)
no... I'll give it a try today though... Thanks
I have tightened up the throtle cable (didn't help). Losened it back up after about a week (didn't want to stretch it)
DAb18c
Jul 9, 2011 12:36 PM
Hanmin
10
Aug 7, 2010 06:25 PM
SuM Honda
Jan 1, 2010 07:29 PM
stockgreencivic
Apr 18, 2004 10:05 PM
myhatchrips
Apr 13, 2003 02:51 PM
