ITR quarter panel problem
If you take it to a good body shop you won't be able to tell it was even replaced. I just bought a R and the carfax showed that it was accident free and when I stripped the interior I found out that the quarter panel had been replaced but they did such a good job I didn't even notice.
You could do it right by replacing the entire 1/4 panel skin, or just have them replace that bottom section and use a seam across the skin itself.(this will look shitty if they aren't pimps when it comes to auto body.)
Awww, that chit will buff out...
Seriuosly though, I had some quarter panel damage on my Teg... I took it to Acura's body shop, you can't even tell...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spids5 »</TD></TR><TR><TD CLASS="quote">If you take it to a good body shop you won't be able to tell it was even replaced.</TD></TR></TABLE>
Shop the caR around and get opinions from the body guys also. We may not be able to see the severity of the damage by the pics.
You can purchase a new Acura OEM quater panel for 330ish which is a touch over cost. I would just find a great body guy who will do the install correctly and then a good painter to go over the panel after the install.
This is what I had to do with my car a few months back. Total cost including parts was in the 1500 range. Not bad at all for a new panel that looks perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smitdog »</TD></TR><TR><TD CLASS="quote">You can purchase a new Acura OEM quater panel for 330ish which is a touch over cost. I would just find a great body guy who will do the install correctly and then a good painter to go over the panel after the install.
This is what I had to do with my car a few months back. Total cost including parts was in the 1500 range. Not bad at all for a new panel that looks perfect. </TD></TR></TABLE>
I had my passanger quarter replaced about a year and a half ago by the Honda dealer and you can never tell anything happened, although I paid a little bit more for my quarter and that was at cost(must have been a shortage then)
