Axle Question for K "Gurus"
Old Jun 4, 2005 | 09:14 PM
IM ALL BOB's Avatar
Default Axle Question for K "Gurus"
Well the question I have for you is this
Are all K20A axles identical? such as K20A ITR vs K20a3 civic si?
if they are not is there a length difference? Because looking at various
specs of Civic si vs RSX TYPE S...track width of both cars, show RSX slightly
wider but only by so much. Which could be caused due to offset and suspension design. Any info would be appreciated, as I have done a bit
of research into it but yet to find any good info
Thanks in advance
Old Jun 5, 2005 | 12:46 AM
aznboysrfr's Avatar
Default Re: Axle Question for K "Gurus" (IM ALL BOB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IM ALL BOB &raquo;</TD></TR><TR><TD CLASS="quote">Well the question I have for you is this
Thanks in advance </TD></TR></TABLE>
from what I've researched:
DC5R axles are 1 inch wider on both sides than K20a2 axles
DC5R/S axles have a 36mm spline
DC5/EP3 axles have a 32mm spline ... auto base RSX axles are the same as the manual as well
Old Jun 5, 2005 | 08:29 AM
funz0rzies's Avatar
the older ep3 axles are 4 lug. the newer ones are 5 lug.
(correct me if i'm wrong)
Old Jun 5, 2005 | 08:49 AM
aznboysrfr's Avatar
Default Re: (funz0rzies)
^ base rsx axles are 5 lug as well, however they are the same ... I think the 04-05 axles may be the same as the base rsx
Old Jun 5, 2005 | 10:16 AM
johnkimble's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funz0rzies &raquo;</TD></TR><TR><TD CLASS="quote">the older ep3 axles are 4 lug. the newer ones are 5 lug.
(correct me if i'm wrong)</TD></TR></TABLE>
Old Jun 5, 2005 | 08:10 PM
IM ALL BOB's Avatar
I am not speaking of hubs or any other part but the Axle(driveshaft itself) but thanks for putting all your .02 in much appreciated.. I will have to continue to look
ek_si hatch
Jun 3, 2008 11:17 AM
way2much
20
Dec 28, 2007 05:37 AM
-DesTiNy-
50
Aug 14, 2006 07:42 PM
high_on-rice
Jul 25, 2004 12:14 PM
iamchocolatemilk
38
Apr 18, 2002 12:10 PM
