steering wheel is making a clicking noise
Old Jun 4, 2005 | 08:39 PM
devilpuppy's Avatar
Default steering wheel is making a clicking noise
i've noticed that when i turned my steering wheel (in either direction) it clicks.
i have no idea what this is, but i'm postivie it never clicked before
any assistance would be great
its a 96 accord coupe
thanks
Old Jun 4, 2005 | 10:12 PM
RUBZERK's Avatar
Default Re: steering wheel is making a clicking noise (devilpuppy)
Mine squeeks
Old Jun 4, 2005 | 10:51 PM
Confuc1ous's Avatar
Could it be that you might need new axle shafts? I had the same problem a few years ago with one of my accords that I had back then and it turned out to be the axle shafts that need replacement.
Old Jun 5, 2005 | 12:11 AM
deserthonda's Avatar
need to be a bit more specific where the noise is coming from....
inside car at steering wheel??? or outside area,,does it click even if you are not moving andjust turning wheels??
Old Jun 5, 2005 | 06:24 AM
devilpuppy's Avatar
Default Re: (deserthonda)
seems like its inside teh car....yup, even if i'm sittin in my driveway and turn the wheel, it makes the clicking sound
Old Jun 5, 2005 | 06:54 AM
RUBZERK's Avatar
Default Re: (devilpuppy)
Mine squeaks where the steering wheel meet the column
Old Jun 5, 2005 | 08:25 AM
Confuc1ous's Avatar
Default Re: (RUBZERK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">Mine squeaks where the steering wheel meet the column</TD></TR></TABLE>
Could some WD-40 get rid of the squeek? Is it the same kind of squeek as a door would make?
Old Jun 5, 2005 | 04:33 PM
devilpuppy's Avatar
Default Re: (Confuc1ous)
mine doesnt squeak
Old Jun 6, 2005 | 06:16 AM
Turbowa's Avatar
You could have a bad clock spring or cable reel. This is the part that keeps all the wiring behind the steering wheel from getting all mangled up when you turn. Its fairly easy to replace.
Old Jun 6, 2005 | 08:52 AM
G4M3JUNKY's Avatar
are you signaling when you hear it because when i signal for a turn and i turn the wheel in that direction it makes the noise. i think it is normal because it just might be a pressure thing to tell the blinkers to turn off automatically.
Old Jun 6, 2005 | 09:09 AM
devilpuppy's Avatar
Default Re: steering wheel is making a clicking noise (G4M3JUNKY)
no...nothign to do with signalling, anytime, anywhere i am, if i turn the wheel in either direction, it makes a clicking sound
Old Jun 6, 2005 | 09:14 AM
G4M3JUNKY's Avatar
well if its clicking i guess theres nothing wrong with it because things click in real life and its ok. If it was making like a really bad noise then id say it is bad. is the clicking noise really loud and noticable?
Old Jun 6, 2005 | 09:23 AM
Turbowa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G4M3JUNKY &raquo;</TD></TR><TR><TD CLASS="quote">well if its clicking i guess theres nothing wrong with it because things click in real life and its ok. If it was making like a really bad noise then id say it is bad. is the clicking noise really loud and noticable?</TD></TR></TABLE>
You have got to be smoking crack if this is how you look at things.
Like I stated before you probably have a bad clock spring or cable reel. These are the same parts just to clearify.
Old Jun 6, 2005 | 09:59 AM
devilpuppy's Avatar
Default Re: steering wheel is making a clicking noise (Turbowa)
i think i need to go for an alignemtn
cuz my car jumped the curb..all 4 tires..so i think the alignemtn might fix it, or help find the problem
Old Jun 6, 2005 | 10:14 AM
Confuc1ous's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">i think i need to go for an alignemtn
cuz my car jumped the curb..all 4 tires..so i think the alignemtn might fix it, or help find the problem</TD></TR></TABLE>
you lost me on that one.
Old Jun 6, 2005 | 11:44 AM
devilpuppy's Avatar
Default Re: steering wheel is making a clicking noise (Confuc1ous)
about one month ago, i lost control and my car jumped teh curb...like all FOUR tires went off the road
so now i hear that clicking sound, and i still havne't gone for an alignment (cuz of the curb)
Old Jun 6, 2005 | 01:49 PM
yo G4 no offense buddy but seems to me that to you everything is normal ..
drive car put cruise on if it does not work could have a broken cable reel...
is noise coming from top or at bottom of steering wheel column?? is it coming from inside steering wheel ??
Old Jun 6, 2005 | 02:35 PM
H2290's Avatar
First off, does it sound like it's coming from inside the steering column cover or somewhere in the engine.
If it's inside the cover it's probably as stated before. If from engine bay probably CV joints. Look under the car near the front wheels for some rubber boots. Are they torn or is anything leaking from them?
Old Jun 6, 2005 | 04:12 PM
NAiL05's Avatar
If Inside Follow the Steering wheel down there should be a boot with a u joint inside. If i remember it should be right behind the brake pedal. That could be whats causing the squeaking. Just lube that up and u should be good. But as deserthonda said is it comin from the bottom or top of the steering wheel column.
Modified by NAiL05 at 7:40 PM 6/6/2005
Old Jun 6, 2005 | 05:06 PM
devilpuppy's Avatar
my cruise control works fine
i hear it in my car at the wheel, not outside, but if i have the music on, i dont hear anything
so bascially take off the cover where the ash tray is, and look up?
Old Jun 6, 2005 | 07:36 PM
cmrvi1's Avatar
[QUOTE=devilpuppy]i've noticed that when i turned my steering wheel (in either direction) it clicks.
Don't worry devilpuppy, you're not crazy, or alone for that matter.
A lady came to the dealership recently complaining of the same clicking noise in her steering column. I tried to brush it off as normal, but she insisted the noise wasn't always there. So I checked another accord, same year, and sure enough, it did not click. So I removed her steering wheel, and found that the turn signal switch was making noise. Apparently, Honda puts some heavy grease on the cancelling cam in the turn signal switch to dampen the clicking noise when you turn. In her car, the grease had dried up, so it got noisy. I put some heavy grease on it, and send her on her way happy as a wet duck cause the clicking was gone.
Old Jun 6, 2005 | 08:00 PM
devilpuppy's Avatar
Default Re: steering wheel is making a clicking noise (cmrvi1)
but my noise is always there, even if i'm not signalling
and it that is my problem
can u post steps and pictures on how to fix it?
Old Jun 7, 2005 | 10:18 AM
Grodzman's Avatar
He's not crazy... I experianced the same issue as he did during the winter months. Every time you turn the wheel about 15 degrees in either direction, it would make a subtle click, which gets annoying after a while.
Luckily my issue was resolved by the temperature steadily getting warmer in my area, so I think the grease concept is where it's at.
Old Jun 7, 2005 | 11:35 AM
AccordRacing's Avatar
"Don't worry devilpuppy, you're not crazy, or alone for that matter.
A lady came to the dealership recently complaining of the same clicking noise in her steering column. I tried to brush it off as normal, but she insisted the noise wasn't always there. So I checked another accord, same year, and sure enough, it did not click. So I removed her steering wheel, and found that the turn signal switch was making noise. Apparently, Honda puts some heavy grease on the cancelling cam in the turn signal switch to dampen the clicking noise when you turn. In her car, the grease had dried up, so it got noisy. I put some heavy grease on it, and send her on her way happy as a wet duck cause the clicking was gone."
^--- This man is a geniuse. I bought my 96 accord a yr. ago and it has that clicking noise (sounds like the signals are turning off at the slightest turn). and based on what he said .. I know the grease in my seats has dried up so I bet the grease in there did tooooooooooooo .. im gonna go fix it ASAP!
Old Jun 7, 2005 | 06:53 PM
devilpuppy's Avatar
Default Re: steering wheel is making a clicking noise (AccordRacing)
okay, so i was standing at red lights, and started turning the wheel trying to hear the noise
i had my music on, and foot pressed on the brake pedal, and i started spinning the wheel
i heard the clicking, but i felt the noise on my foot as i had the brake pedal pressed down
