D16z6 Mini-Me Swap into D16Y7 HELP Please??
Old Jun 4, 2005 | 06:42 PM
LilLaObOi50's Avatar
Default D16z6 Mini-Me Swap into D16Y7 HELP Please??
Hi i own a 97 civic DX (D16Y7) and im swaping a 95 civic ex (D16z6) head onto my Y7 block. i just wanted to kno how to hook up the Vtec and the ECU and the Vtec Solnoid and stuff. is there anything that i need to buy extra or anything that i need to pull out of my Y7.
Old Jun 4, 2005 | 07:37 PM
freezerburnv2's Avatar
Default Re: D16z6 Mini-Me Swap into D16Y7 HELP Please?? (LilLaObOi50)
from what I remember it's been a while, vtec line is just one green line you can get a vtec ecu should just plug right up if you do same OBD should just plug right up only thing diffrent would be vtec line usually. don't hold me too that it's been a while but like I said only thing diffrent should be Vtec line and how it's engaged with either changed ECU or I've seen vtec engaged with a shift changer light on a Autometer RPM gauge the motor will work fine also before you figure out what your going to do to get vtec going.
Old Jun 5, 2005 | 10:49 PM
wes10_44's Avatar
the sohc vtec solenoid has three wires, ground, vtec(green), and vtec oil preasure sensor(orange i think) also if i remember correctly you have to hook up a knock sensor.
bwr3476_ky
35
Jan 2, 2007 09:22 PM
GreenEHDriver
Jun 13, 2006 06:07 PM
robs93civic
28
Apr 24, 2006 03:46 PM
incognito E46
Mar 19, 2005 03:27 AM
4drsedaneg
Sep 26, 2004 03:54 PM
