1991 CRX SI distributor same as Integra ZC?
Old Jun 4, 2005 | 06:01 PM
02 coupe's Avatar
Default 1991 CRX SI distributor same as Integra ZC?
Like the topic says... how would i beable to tell the difference if they are different?
thx
Old Jun 4, 2005 | 06:09 PM
tony4380's Avatar
Default Re: 1991 CRX SI distributor same as Integra ZC? (02 coupe)
should be the same... whats the code for the 2 dizzys? im not sure of the codes though
Old Jun 4, 2005 | 07:39 PM
FalkenSiR's Avatar
Default Re: 1991 CRX SI distributor same as Integra ZC? (tony4380)
By integra ZC you mean 86-89 D16A1 DOHC??? Or JDM Integra SOHC ZC???
Old Jun 4, 2005 | 09:35 PM
dr_latino999's Avatar
Default Re: 1991 CRX SI distributor same as Integra ZC? (fast88std)
Well, the answer is no unless it is the SOHC 1593cc Non-Vtec OBD-0 ZC (The motor that actually has ZC stamped on the block )
Old Jun 4, 2005 | 10:15 PM
DJ_SaNdOz's Avatar
Default Re: 1991 CRX SI distributor same as Integra ZC? (dr_latino999)
yes, it is if you mean the di6a1 teg. I used the dizzy for an 89 integra for my dohc zc.
Old Jun 5, 2005 | 01:22 AM
02 coupe's Avatar
Default Re: 1991 CRX SI distributor same as Integra ZC? (DJ_SaNdOz)
my bad, ZC as in USDM integra 1.6DOHC. So it will work on both motors?
thx
Old Jun 5, 2005 | 04:57 AM
Sikocivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 coupe &raquo;</TD></TR><TR><TD CLASS="quote">my bad, ZC as in USDM integra 1.6DOHC. So it will work on both motors?
thx</TD></TR></TABLE>
The dizzy from the 91 CRX Si motor will NOT fit the USDM or JDM DOHC motor. It will fit the SOHC ZC but not the DOHC. If you have a DOHC 1.6 motor from the 88-89 teg, and you need a dizzy for it, then you need to get one from the 88-89 teg. None of the ones from the SOHC motors will work.
cdescoteaux
17
Dec 13, 2006 09:04 AM
Drew Peacock
Apr 9, 2005 10:10 PM
89sirex
Jul 7, 2004 02:30 PM
m_mathers_69
Jun 13, 2004 04:37 PM
notfastenough
Nov 5, 2003 01:21 PM
