integra type r brakes into 97 civic coupe
hi there, i have a 97 civic coupe hx and i would like to put integra type r brakes all around. well so far i have AGX and H&R also front and rear ST sway bar kit. i was wondering if i put the integra type r brakes in, would i need to buy new shocks/springs and sway bars? or will it bolt up? thank you
You need to buy the complete 5-lug conversion (or 4x114 if you want the 96 spec). Front a arms, knuckles, rear trailing arms, brake lines, etc. Look to spend $1000+.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">You need to buy the complete 5-lug conversion (or 4x114 if you want the 96 spec). Front a arms, knuckles, rear trailing arms, brake lines, etc. Look to spend $1000+.</TD></TR></TABLE>
it's gonna be 4X114.3, but my question is will the agx/h&r i have in my car rite now work with the integra type r brakes. also will the suspension techniques front and rear sway bar work with the type r brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FLYNLOW »</TD></TR><TR><TD CLASS="quote">
it's gonna be 4X114.3, but my question is will the agx/h&r i have in my car rite now work with the integra type r brakes. also will the suspension techniques front and rear sway bar work with the type r brakes.</TD></TR></TABLE>
They will work just fine after the swap. Just reuse your current front and rear lcas.
They will work just fine after the swap. Just reuse your current front and rear lcas.</TD></TR></TABLE>
that's all i wanted to kow. thank you chowmien
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FLYNLOW »</TD></TR><TR><TD CLASS="quote">hi there, i have a 97 civic coupe hx and i would like to put integra type r brakes all around. well so far i have AGX and H&R also front and rear ST sway bar kit. i was wondering if i put the integra type r brakes in, would i need to buy new shocks/springs and sway bars? or will it bolt up? thank you</TD></TR></TABLE>
So your willing to spend $1000+ on 11inch brakes plus that extra lug stud?
Theres a cheaper way of getting big brakes on a civic.
Get ITR/accord wagon calipers, ITR/prelude brake pads, and custom 11inch 4x100 brake rotors (heeltoe sells them). This setup works with civic si brakes but other civics will probably require additional modification and/or parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP-Si »</TD></TR><TR><TD CLASS="quote">
Get ITR/accord wagon calipers, ITR/prelude brake pads, and custom 11inch 4x100 brake rotors (heeltoe sells them). This setup works with civic si brakes but other civics will probably require additional modification and/or parts.</TD></TR></TABLE>
well see the problem is that i have rear drumb brakes that's why i want to get integra type r 4 lugs (since i found it online for $650 and it include ITR wheels also) but what i think i'm gonna do is buy EJ1 front and rear disc brakes (since my front rotor are warped) and it's only $150. unless u have any other suggestion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FLYNLOW »</TD></TR><TR><TD CLASS="quote">i was wondering if i put the integra type r brakes in, would i need to buy new shocks/springs and sway bars?</TD></TR></TABLE>
No.
No.
VBitter
Oct 8, 2009 07:25 PM
gottalovecivics
May 13, 2007 11:14 PM
