Does anyone know the length of the JDM ITR cat?
Old Feb 8, 2002 | 04:58 PM
travis's Avatar
Default Does anyone know the length of the JDM ITR cat?
If I were to connect a JDM spec. b-pipe to a JDM spec. exhaust manifold, how long would the cat be? I'm hoping I can get a carsound cat made to that length, but it may be shorter than a carsound can be. Thanks for any help!
Old Feb 8, 2002 | 06:23 PM
JDM_DOHC_SiR's Avatar
New User
Default Re: Does anyone know the length of the JDM ITR cat? (ITR#231)
11 and 1/8th or 283mm
Hope this helps ya
Old Feb 8, 2002 | 07:31 PM
NZITR's Avatar
Default Re: Does anyone know the length of the JDM ITR cat? (JDM_DOHC_SiR)
I have the JDM 4-1 Header with a JDM Cat (from a 99 spec car) bolted to a JDM Trust PEII exhaust and it all bolts together perfectly. I measured my cat and it is 305mm (12 Inches) flange to flange which is a little longer than the figure quoted above.. I'm sure this just confuses things
David.
Old Feb 8, 2002 | 08:16 PM
SMSP's Avatar
Default Re: Does anyone know the length of the JDM ITR cat? (NZITR)
When you say flange to flange, do you mean from the B pipe flange gasket surface to where the donut rests against the JDM collector flange? Or in other words if you stood a JDM cat up on a table on its 3 bolt flange and then place a donut in the flared inlet the total height of the cat/donut would be 12"?
Thanks for the help.
Old Feb 8, 2002 | 08:20 PM
SamB's Avatar
New User
David, good to see another Kiwi on the board. You get your car new? and have you thrashed it around the track yet?
Sam
P.S If you haven't already, check out www.nzhondas.com
Old Feb 9, 2002 | 07:05 PM
NZITR's Avatar
Default Re: Does anyone know the length of the JDM ITR cat? (SMSP)
Yes the total effective height would be 12". I have assumed the fixed studs at the 3 bolt end were removed in your illustration
David
Old Feb 9, 2002 | 07:16 PM
NZITR's Avatar
Default Re: Does anyone know the length of the JDM ITR cat? (Sam & Bridget)
Yes I got it new about 14 months ago.. but haven't made it to the track as anything other than a spectator at this point.
Dc2alldawaY
Dec 21, 2007 04:47 PM
Stein
10
Sep 22, 2003 04:19 PM
Skelly
Jul 28, 2003 08:20 AM
EVIL_AWD
May 3, 2003 09:02 PM
ARunto
Jul 14, 2002 06:35 PM
