Fuel Problem.. Car dies, then fires but will not start.. then starts after 5-10 Minutes
Old Jun 4, 2005 | 04:57 PM
jhr1969's Avatar
Default Fuel Problem.. Car dies, then fires but will not start.. then starts after 5-10 Minutes
I have been haveing this problem for a few months, and tonight my little Honda died. I am driving a 92 Civic VX, stock 1.5v, no mods.
This problem usually happens when I make a few quick stops, at some point it starts but then powers down. After trying for 5-10 minutes, with semi-starts, it will start and run again. Well tonight it would not fully start, then finally no fire at all.
A mechanic friend told me that Honda has a relay problem, and that I need to get a new main relay. However I think he is wrong. So I figured I would ask in a forum. When I turn the key, I can hear the fuel pump power up. A relay if bad would cause the fuel pump to not work correct?
Any help or ideas would be appriciated..
Thanks in Advance
John
Old Jun 4, 2005 | 04:59 PM
Zeus Zore's Avatar
Default Re: Fuel Problem.. Car dies, then fires but will not start.. then starts after 5-10 Minutes (jhr196
your mechanick is not wrong ! sounds very much like the fuel relay ! (main relay)
but dont buy a new one ! just resolder it... takes no more then 30 mins 2 do .. and you will bee happy ever after with your honda..
Old Jun 4, 2005 | 05:01 PM
Zeus Zore's Avatar
hmm read the last part last.. positiv you hear the fuel pump ? but still
the prob is bad connection in the relay.. try it !!
first thing resolder the main relay ! .. come back if the prob still there ( i would belive it would be over ..
jhr1969's Avatar
umm, I may be good at computers, but im an idiot with cars. well if I have a manual, I can do just about anything.. is there a tech manual on how to do what your saying? I was going to buy the relay tomorrow from the dealership, but if told exactly what to do, Id like to try would I have to pull the relay out of its holder??
Ok I have the relay out of the case, and I see the solder points .. im assuming all I need to do is apply heat to the points, and after the solder melts, then I add new solder.. is that correct
Old Jun 5, 2005 | 04:45 AM
jhr1969's Avatar
bump
Is there a certain grade of Solder I need to use?
The dealer here used to be open on Sundays, but no longer so I need to try the solder trick and see if I can get my car running today.
Thanks
John
Modified by jhr1969 at 7:10 AM 6/5/2005
Old Jun 5, 2005 | 06:53 AM
Crasian's Avatar
my car did the exact same thing, this link should help u. BTW the main relay is located rite by the fuse box under the dash http://www.markl.f9.co.uk/howt...y.htm
Old Jun 5, 2005 | 07:31 AM
jhr1969's Avatar
Default Re: (FarOutCoupe)
Thank you so much, now I need to go buy supplies and fix my little mule..
Regards
John
Old Jun 5, 2005 | 04:00 PM
Crasian's Avatar
no problemo, good luck man!
KYLE.ECKERT
Dec 8, 2012 01:59 PM
young geezer
Jun 29, 2009 09:53 PM
oakpwr
Jan 20, 2007 12:05 PM
tomu06
Aug 7, 2006 12:02 PM
mercury
Jul 16, 2002 07:15 PM
