ENGINE SWAP NEED HELP CRANK NO START-B18C5 INTO EJ1
Old Jun 4, 2005 | 04:24 PM
1 SiC EJ1's Avatar
Default ENGINE SWAP NEED HELP CRANK NO START-B18C5 INTO EJ1
I JUST SWAPED B18C5 IN TO MY 93 EJ1. EVERYTHING IS HOOKED UP AND ITS GOT A P72 ECU WITH AN ERICKS RACING CHIP. THE MOTOR CRANKS AND DOESNT START I CHECKED THE FUEL AND ITS GETTING THROUGH THE FUEL RAIL, I KNOW THE SPARK PLUGS ARE GOOD BECAUSE THE MOTOR ONLY HAD 40K ON IT, CAN ANYONE HELP ME ON THIS. CUZ IM AT A LOSS.
Old Jun 4, 2005 | 05:42 PM
Crazydave's Avatar
Default Re: ENGINE SWAP NEED HELP CRANK NO START-B18C5 INTO EJ1 (numba 1 stunna)
so you are getting pressure at the fuel rail... are your injectors working.
Are you getting spark at all?
in order for your engine to run, it needs fuel, air, compression and spark in the cylinders
Old Jun 4, 2005 | 06:41 PM
onepoint6i's Avatar
Default Re: ENGINE SWAP NEED HELP CRANK NO START-B18C5 INTO EJ1 (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">
in order for your engine to run, it needs fuel, air, compression and spark in the cylinders</TD></TR></TABLE>
w3rd
Old Jun 5, 2005 | 07:59 AM
Suck my DX's Avatar
Default Re: ENGINE SWAP NEED HELP CRANK NO START-B18C5 INTO EJ1 (1.6i)
i know i change my spark plugs more often than every 40k..u should too
Maidumechanic
Feb 14, 2013 05:39 AM
h22a_93accord
Apr 25, 2008 05:23 PM
MoogieBoogie
Apr 24, 2004 01:49 PM
H22FAN
Mar 25, 2004 02:16 PM
APEX i GSR
12
Dec 10, 2002 08:32 PM
