TPS adjustment question?
Old Jun 4, 2005 | 03:35 PM
civic94B18B1's Avatar
Default TPS adjustment question?
I have a b18b1 that has a throttle position sensor from a d15 because the original was broken. I recently installed a tach and found that my rev limitor is kicking in at 6500 rpm. The tps also has a bit of damage to it but i want to adjust it and see if it works.Could somebody please tell me how to adjust it.
Old Jun 4, 2005 | 04:28 PM
Lord Helmet's Avatar
Default Re: TPS adjustment question? (civic94B18B1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic94B18B1 &raquo;</TD></TR><TR><TD CLASS="quote">I have a b18b1 that has a throttle position sensor from a d15 because the original was broken. I recently installed a tach and found that my rev limitor is kicking in at 6500 rpm. The tps also has a bit of damage to it but i want to adjust it and see if it works.Could somebody please tell me how to adjust it. </TD></TR></TABLE>
Using a multimeter measure the yellow/blue(+) wire and the green/blue(-) wire at idle. It should read 0.5 Volt and at full throttle: 5 volts. BTW there should be a smooth transition as the throttle is depressed.
If it is not at 0.5 volts at idle or 5 volts at full throttle, slightly adjust(move/wiggle) the TPS until it reaches 0.5 v or 5 v. Once it reaches the factory specs 0.5 volts at idle tighten the bolts holding the TPS. And also clear your codes when you are done which is common sense anyways.
Old Jun 4, 2005 | 05:57 PM
TeamNextGenChris's Avatar
what year D15 was the TPS off of?an OBDI model,or an older one?
Chris
Old Jun 5, 2005 | 01:03 AM
Default Re: TPS adjustment question? (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">what year D15 was the TPS off of?an OBDI model,or an older one?
Chris</TD></TR></TABLE>
It's off a 94-OBD1
Old Jun 5, 2005 | 03:14 PM
It's off a 94-OBD1</TD></TR></TABLE>
okay.have you done the procedure above to test/calibrate it?
Chris
Old Aug 10, 2006 | 04:50 AM
MKIIISupra's Avatar
Can you calibrate the TPS with the car off and the key on, or does the car have to be running?
Old Aug 10, 2006 | 01:12 PM
1sikhatch's Avatar
Default Re: TPS adjustment question? (MKIIISupra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MKIIISupra &raquo;</TD></TR><TR><TD CLASS="quote">Can you calibrate the TPS with the car off and the key on, or does the car have to be running?</TD></TR></TABLE>
i would also like to know this....
Old Aug 10, 2006 | 01:32 PM
Braco11's Avatar
Default Re: TPS adjustment question? (1sikhatch)
engine should be OFF. but key should be turned to the on position.
Old Aug 10, 2006 | 02:07 PM
:Andrew's Avatar
Default Re: TPS adjustment question? (Braco11)
it's actually 0.5v at idle and 4.5 full throttle
Old Aug 10, 2006 | 02:13 PM
1sikhatch's Avatar
Default Re: TPS adjustment question? (:Andrew)
thanks alot i'll go do mine tomorrow, hopefully my car will be running better.
Old Aug 10, 2006 | 02:17 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :Andrew &raquo;</TD></TR><TR><TD CLASS="quote">it's actually 0.5v at idle and 4.5 full throttle</TD></TR></TABLE>
Old Aug 13, 2006 | 11:58 AM
1sikhatch's Avatar
Default Re: TPS adjustment question? (94eg!)
did this and now my car sputters at idle and after the vtec kicks in and it feels week.
rjr162
Dec 1, 2007 11:32 AM
dmxsoulja3
Dec 16, 2004 05:56 PM
kholmes
Oct 12, 2004 06:59 PM
90crxb16a
Oct 25, 2003 07:35 AM
evo
Apr 9, 2002 09:39 PM
