Tranny Binding !!!
Old Jun 4, 2005 | 02:59 PM
NXSpoon's Avatar
Default Tranny Binding !!!
I bought a busted (synchros) GSR tranny and just replaced the internals w/ B16 gears and mainshaft, a CTR limited slip, a JDM FD and countershaft set and all new Type R synchro sleeve sets. When the case was closed, the mainshaft was extremely hard to turn. It was able to be turned using a clutch disk to provide leverage. It was installed on the car, and started making a clanging noise that seemed to come from the bell housing, but it might not be. Just that the bell housing might have increased the noise. It engaged in first and reverse (I didn't dare take it out of the driveway), but was extremely difficult to remove the shift lever from the reverse position.
Anyone have any ideas?? I have not removed it from the car yet, since it is at my friend's house. I am hoping to take a look at it tomorrow.
Thanks,
Ken
Old Jun 4, 2005 | 04:18 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Tranny Binding !!! (NXSpoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXSpoon &raquo;</TD></TR><TR><TD CLASS="quote">When the case was closed, the mainshaft was extremely hard to turn. It was able to be turned using a clutch disk to provide leverage. It was installed on the car, and started making a clanging noise that seemed to come from the bell housing, but it might not be. </TD></TR></TABLE>
Damn, why did you install that? It should have turned freely.
http://www.acuraparts247.com/s...ch=no
Did you install part #11 correctly?
Old Jun 4, 2005 | 04:43 PM
NXSpoon's Avatar
Default Re: Tranny Binding !!! (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
Did you install part #11 correctly?</TD></TR></TABLE>
Yes, #11 was installed correctly. We decided to put it back on because we were thinking that it was turning (although with difficulty), making no noises and since the parts were new that it would break in when the case was together and filled with fluid.
Old Jun 4, 2005 | 08:57 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
where in fl are you? you might be near and i could help. could be several things...i could tell you what it was if i looked at the tranny. who did the assembly and have they worked on transmissions before?
Old Jun 4, 2005 | 10:02 PM
NXSpoon's Avatar
Default Re: Tranny Binding !!! (not so civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic &raquo;</TD></TR><TR><TD CLASS="quote">where in fl are you? you might be near and i could help. could be several things...i could tell you what it was if i looked at the tranny. who did the assembly and have they worked on transmissions before?</TD></TR></TABLE>
I am in Spring Hill area. Both my friend and I have done multiple tranny rebuild before. This is a new problem that neither of us has seen before. I will be going over in the morning to start the teardown. Should have results by tomorrow night.
Keep the suggestions coming !!
Thanks.
EG-evokilla
Transmission & Drivetrain
Feb 26, 2009 09:06 AM
amej8
Apr 7, 2008 04:14 PM
pokmijn
Dec 2, 2007 06:18 PM
boosted civic 2k6
Aug 23, 2005 10:00 PM
SuicideSlide
Sep 19, 2003 10:57 AM
