Radius rods...
Old Jun 4, 2005 | 11:01 AM
i20ar's Avatar
Default Radius rods...
ive seen i went to get my car aligned and guy told me i had the wrong radius rods on my passenger side... i went to the shop where i got some work done on my car... and they put the wrong size radius rod on my passenger side. i went to teh shop they gave me new parts.. but i dont know if there the right ones..
and also can somes one tell me the differnce between each
Old Jun 4, 2005 | 07:58 PM
hawkimport's Avatar
Default Re: Radius rods... (DJ14aZnS)
The top pic are ones from a Manual Accord
The lower pic is one from a AUTOmatic (YUCK) They are BFE
Old Jun 5, 2005 | 12:32 AM
deserthonda's Avatar
what year car do you have???
the top looks like for a 86-89 accord
the bottom for a 90 -93
Old Jun 5, 2005 | 11:46 AM
i20ar's Avatar
Default Re: (deserthonda)
i have a 96 5-speed ... i took my car to get aligned and they said they had the wong radius rod on my car.. i looked uder and its seems that i have the 2 top ones.. . the guy at the alignment shop sayed i needed and adjustable one
Old Jun 5, 2005 | 11:58 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">
Those dont look like it to me, the 86-89 were adjustable.
Old Jun 5, 2005 | 04:31 PM
::MYCORD::'s Avatar
Default Re: (Chiovnidca)
The very top one looks like it is the ones for the 5th gen. Mine looked like those. Another thing, those things are only adjustable by adding or taking off the washers that the radius rod connects to the subframe with, but that's only for really small adjustments
Old Jun 5, 2005 | 07:58 PM
s.cali alan's Avatar
the top ones are right. the bottom one is from who knows where....
the auto and 5spd are the same. the auto ones are not BEEFIER
the passenger side one is also the curvier of the two of the above picture.
eric is right about the shims. each "washer/shim" between the radius rod and the subframe (on the side of the wheelwell) adds about 1 deg of caster. HOWEVER, its quite a bitch to add those shims.
Old Jun 5, 2005 | 08:02 PM
i20ar's Avatar
Default Re: (s.cali alan)
the bottem one is from the passenger side auto transmition accord.. its made that way becuase unlike the 5-speed the auto transmition is in the way so the rod goes under it thats why its bent like that.. i need to find an adjustable radius rod... i heard its a custom auto part tho..
Old Jun 6, 2005 | 02:30 AM
Chiovnidca's Avatar
Default Re: (DJ14aZnS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ14aZnS &raquo;</TD></TR><TR><TD CLASS="quote">.. i need to find an adjustable radius rod... </TD></TR></TABLE>
Why? Is something in the suspension bent?
Old Jun 6, 2005 | 04:26 AM
TouringAccord's Avatar
H-T Order of Merit
just to clarify...
The radius rods in the top picture are from a 1995 Accord EX 5spd. I know because those are my pictures from my totalled Accord.
The radius rod in the lower picture is from a 94-97 automatic I believe. I'm not sure because I recieved it with a passenger side LCA I bought from a junkyard and they just left it on there. The LCA was marked as coming from a 94 Accord and that was it.
Why do you need some custom part? As long as nothing is bent in your suspension then the washer shims used to adjust the radius rods should be enough.
What year/model/tranny do you have?
Old Jun 6, 2005 | 01:37 PM
yo Chio i stand corrected you are right up to 89 accords they had adjustable caster on rods
Old Jun 6, 2005 | 02:53 PM
i20ar's Avatar
Default Re: Radius rods... (TouringAccord)
got a 96 ex.. i think somthing in the fram might be bent all i need is an extra 2 deg. =/ but they need the custom one for that
Old Jun 7, 2005 | 03:29 AM
H-T Order of Merit
if something is bent, you should find out what is and either replace it or have it fixed. Then you probably won't need the custom radius rod.
Are you sure it isn't your radius rod that is bent? Have you hit any curbs or big pot-holes or anything lately?
Arrensaur
Jun 6, 2012 04:49 PM
95AccordSC
Mar 11, 2009 12:15 PM
EF8 D-UNIT
Dec 24, 2005 07:18 PM
Tinytorr
Mar 16, 2004 09:14 AM
Blue10karat
Sep 8, 2003 05:14 PM
