Do I need to get new valve springs to run Civic Type R cams?
Old Jun 4, 2005 | 05:27 AM
LSV_REX's Avatar
Default Do I need to get new valve springs to run Civic Type R cams?
Any help would be appreciated. (Either skunk2 stage 1 or civic typer r.)
Old Jun 4, 2005 | 06:14 AM
d357r0y's Avatar
Default Re: Do I need to get new valve springs to run Civic Type R cams? (LSV_REX)
Some say yes, some say no. Personally I am.
This has been covered a few times.. try the search.
Old Jun 4, 2005 | 09:50 AM
hahagasdcrx's Avatar
Default Re: Do I need to get new valve springs to run Civic Type R cams? (d357r0y)
if you are staying with the same rev limit, you will be safe for a little while. But if you want to take your rpm's just a little higher i would replace them.
Old Jun 4, 2005 | 10:00 AM
Suck my DX's Avatar
Default Re: Do I need to get new valve springs to run Civic Type R cams? (hahagasdcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSV_REX &raquo;</TD></TR><TR><TD CLASS="quote">Any help would be appreciated. (Either skunk2 stage 1 or civic typer r.)</TD></TR></TABLE>
those are both pretty mild cams so no you dont NEED to but i would...what u got a 1st gen b16...u wouldnt really even need to go above your stock limit...if u did u wouldnt really be makin much power..but if u have the funds i say change em
Old Jun 4, 2005 | 10:40 AM
Nerologic's Avatar
if anything just to be safe, i would run a set of inner springs (stock or aftermarket)
the stock outer and stock retainers with the help of some inners work perfect and last a long time..
Old Jun 5, 2005 | 05:11 PM
LSV_REX's Avatar
Default Re: (Nerologic)
I have a first gen b17 head. Its LS/VTEC but its balanced with King race bearings. I still will never rev over 8500. Even 8200rpm is pushing it. So if I can get away with stock valve springs I will.
Old Jun 5, 2005 | 05:14 PM
kid-crx's Avatar
my b16a has itr cams with stock springs and retianers and they pull really hard all the way to 8200 rpms (stock rev. limit) i dont plan on reving any higher then that so u should be fine on stock springs and retianers just keep it around stock rev. limit
kphamx
Sep 20, 2007 12:51 PM
EITCP
12
Apr 22, 2006 11:22 AM
grenthang
Mar 13, 2005 11:57 AM
lakerschamp2000
Feb 28, 2005 03:32 PM
TypeR582
Feb 13, 2002 10:05 AM
