Suspension & Brakes Theory, alignment, spring rates....
Alignment question
Old Jun 3, 2005 | 08:11 PM
ahs2m2's Avatar
Default Alignment question
Just got my alignment done and this is from the spec sheet.
Front left (camber -1.2) (Caster 1.0) (Toe 0.01)
Front Right (camber -1.0) (Caster 1.7) (Toe 0.02)
Rear left (camber -2.6) (toe 0.07)
Rear right (camber -1.7) (toe 0.03)
The camber cannot be adjusted. I can tell my car is pulling to the right, tell me what is still wrong.
Thanks
Old Jun 3, 2005 | 09:15 PM
veggiemaster's Avatar
Default Re: Alignment question (ahs2m2)
Your camber cant be adjusted? what kind of an alignment shop did you go to?
and if you paid for them to do that, i would take it back and tell them to fix your rear camber correctly, or give you your money back. The only reason that you wouldnt be able to adjust camber, is if something is bent, or damaged. Any evidence of this?
and as far as your car pulling, check your brake calipers, one may be dragging. If they are old, then its a good possibility.
Old Jun 3, 2005 | 11:31 PM
mastarolla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahs2m2 &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks</TD></TR></TABLE>
Front right caster could cause the pull... and caster is the measurement which cannot be adjusted. It usually indicates worn suspension components or bent control arms if its out of proper specs
Old Jun 6, 2005 | 12:02 AM
EJ8tunerman's Avatar
Default Re: Alignment question (mastarolla)
If the diff. between left and right is more than .5 on camber, then it will pull to the side with the MOST positive camber, in your case, the right side. Caster will usually begin to cause directional instability when the diff. between left and right wheels are more than 1 degree of difference. Basically in ur case, u have both working against you,(right camber .2+ and right caster .7-) which will most likely be the culprit of the slight right pull.
bopbop93030
Suspension & Brakes
Apr 8, 2008 04:08 PM
bopbop93030
Apr 6, 2008 08:32 AM
sk8shorty012
23
Nov 14, 2006 10:59 AM
.E
Suspension & Brakes
Dec 4, 2005 08:34 PM
yoshi234
Dec 27, 2001 01:11 PM
