car sits higher on one side!
Old Jun 3, 2005 | 07:22 PM
Ch3mik's Avatar
Default car sits higher on one side!
I have KYB AGX all around on skunk2 coils. I have it set at the lowest settin all aound and the pass side front sits about 1.5" higher than the other sides of the car. I thought maybe the shock but I put a brand new one in last nite. I dont know what the hell else it could be. anyone else have this happen? help. lol. I dont want my crx to look gimpy
Old Jun 3, 2005 | 08:41 PM
TheCheeseWedge's Avatar
Default Re: car sits higher on one side! (Ch3mik)
when you lowered it did you be sure to cut the bump stop in 1/2 and not use the dust cover. also check if the spring has set in the hat
Old Jun 3, 2005 | 11:02 PM
hahagasdcrx's Avatar
Default Re: car sits higher on one side! (TheCheeseWedge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheCheeseWedge &raquo;</TD></TR><TR><TD CLASS="quote">when you lowered it did you be sure to cut the bump stop in 1/2 and not use the dust cover. also check if the spring has set in the hat</TD></TR></TABLE>
Could be some of them factors. Hell, maybe your car likes that gangsta lean...
Old Jun 3, 2005 | 11:06 PM
Tyson's Avatar
its pretty normal actually that the driver side is lower. pretty typical for a car 14-17 years old. you can alleviate some of it by resetting your bushings. basically put your car on jack stands. loosen your lower control arm bolts (inner and shock bolt) and upper control arm bushings (these are kind of hard to get to) for the fronts. upper control arm (just the outer bushing) and lower control arm bolts in the rear. then jack up one corner at a time until the weight of the car is off the jack stand. then tighten each of the bushings at that corner.
its actually specified in the factory shop manual. its often overlooked. im not saying its going to solve your problem. the problem is that its got over a decade of abuse and unevenly worn bushings. otherwise, just get used to it. it was probably that much different before you swapped springs, you just didnt notice it because the wheel gap was bigger. now its closer so it brings it more to attention. overall, its normal.
Old Jun 4, 2005 | 10:12 AM
o another thing i remebered is, do you have a camber kit, if so then your upper control arm might be resting on your fender not allowing your car to lower. mine did that when i installed a camber kit on my crx
Old Jun 4, 2005 | 08:15 PM
Ch3mik's Avatar
Default Re: (TheCheeseWedge)
i was thinkin that but i shaved on the CA already. it does have a camber kit. i felt a spot on the inside that kinda sticks out but the arm isnt restin on it. : /
JENNY_EG6
Suspension & Brakes
13
Oct 24, 2010 12:59 PM
91Ef4dR
Oct 21, 2008 01:36 PM
DB1_559
Suspension & Brakes
May 18, 2008 03:27 PM
.1type.
Aug 7, 2007 01:42 PM
Flava
Suspension & Brakes
May 29, 2006 11:25 AM
