Si tranny in an HF??
Old Feb 8, 2002 | 01:37 PM
REDBARON's Avatar
Default Si tranny in an HF??
Ok guys here's my question. I'm going to be putting a ZC in my Hf rex in the very near future, but I was wondering if an Si tranny is able to bolt on to the HF motor?? Just trying to upgrade a little at a time. Also do I need to change out knuckles, hubs, or axles when I do my ZC swap??
Thanks guys.
Old Feb 8, 2002 | 01:43 PM
keithv's Avatar
Default Re: Si tranny in an HF?? (VTECHatch)
i'm pretty sure the zc axles are larger than the hf ones, so yes, the knuckles and hubs will have to be changed to si or teg ones.
Old Feb 8, 2002 | 01:55 PM
REDBARON's Avatar
Default Re: Si tranny in an HF?? (breaka_1_9)
So will the Si tranny fit the HF engine?
Old Feb 8, 2002 | 02:03 PM
HCrip's Avatar
All D-series cable trannies mount up to all D-series motors and fit in EF's
Now, HF and dx STD have smaller knuckles, which need to be replaces. Just get SI knuckles and that's it. Caliper and rotors will work fine. If I'm wrong, correct me please.
PS. My .02, don't waste your time installing the Si tranny, just leave it out, get some knuckles, si axles, and get the zc long block.
[Modified by HCrip, 3:05 PM 2/8/2002]
*Boostwerks*'s Avatar
All that you need if you use the SI tranny:
*SI or DX Hubs/Knuckles
*SI/or DX stock axles.
All that you need if you use the ZC tranny with the halfshaft:
*90-93 teg axles.
That is all.
[Modified by Bryson, 11:04 PM 2/8/2002]
[Modified by Bryson, 11:10 PM 2/8/2002]
Old Feb 8, 2002 | 02:05 PM
ALL the 88-91 D series trannies will be interchangable
Old Feb 8, 2002 | 02:25 PM
wronghand's Avatar
You can use the Si tranny with your current set up. You will need to use the HF axles. It would not be a bad idea at some point to upgrade to the DX or Si knuckles, hubs and disc brakes. The Si/DX brakes are slightly larger. I hope this helps.
Old Feb 12, 2002 | 05:55 AM
REDBARON's Avatar
Default Re: Si tranny in an HF?? (wronghand)
Hey thanks for the info guys.
Old Feb 12, 2002 | 06:10 AM
Trinity's Avatar
hmmmm ok so would that be the same on a STD hatch? just wondering because i bolted a si tranny up to my std motor just fine without any changes
Old Feb 12, 2002 | 07:01 AM
HCrip's Avatar
Default Re: Si tranny in an HF?? (Trinity)
I have a Std as well, it's not a DX, just FYI. Also, the knuckles are the same as HF's. So, if you are thinking of a b-series swap, gotta change them out. Great upgrade woulud be EX calipers/rotors/knuckles. 10.3" compared to 9.5" and you can get them for all for $150! That's a steal in my books. goto http://www.jdmhondaparts.com/frameset.htm
hondaboy90
May 30, 2006 02:32 AM
PBrex
Feb 6, 2004 05:13 PM
crxxrc
Jan 15, 2004 05:53 AM
pdiddyparsons
Feb 18, 2003 11:34 AM
Civicboy
23
Jun 28, 2002 09:26 AM
