Looking for safe cam to run with .5 mm os valves
Old Jun 3, 2005 | 04:46 PM
vtecmissle's Avatar
Default Looking for safe cam to run with .5 mm os valves
I was wanting to run skunk 2s. Last time i posted rlz suggested head setup would make it ok. I was wondering if anyone else had ran these with the same os valves. Is there a similar performance cam that will allow me to use these valves.
Old Jun 4, 2005 | 02:30 PM
vtecmissle's Avatar
Default Re: Looking for safe cam to run with .5 mm os valves (vtecmissle)
i should have clarified skunk 2 stage 2s or maybe i could use pro 1s. Any help. The engine is a b18c1 engine with mild port work and supertech valves and springs with ti retainers.
Old Jun 7, 2005 | 02:12 PM
vtecmissle's Avatar
I guess no ones smart enough to answer this one. Ill have to call larry i guess.
Old Jun 7, 2005 | 02:15 PM
johnzm's Avatar
LOL@larry comment.
i do believe that u can run ANY cam on the market with proper assembly and measurements.
thats not to say u will make power, since tbone made more power from going from a larger valve to a smaller valve, on a 255hp motor
Old Jun 7, 2005 | 06:41 PM
vtecmissle's Avatar
Default Re: Looking for safe cam to run with .5 mm os valves (johnzm)
thanks that was my line of thinking also. I would also guess that it includes delicate cam gear settings and timing belt servicing. THanks
soulpwr
22
Jun 13, 2007 07:44 AM
sibluecrx
Feb 1, 2007 08:50 PM
Speed Infliction
Apr 19, 2006 11:32 AM
vtecmissle
Oct 8, 2005 09:02 AM
GIZZ - EXV
Apr 25, 2004 08:43 PM
