pr3 and pw0 chips interchangeable?
Old Jun 3, 2005 | 12:49 PM
xDicktonesx's Avatar
Default pr3 and pw0 chips interchangeable?
i got a DIP socket and a chip to solderin but its labled PWO. i have a pr3 ecu. does it make a difference?
Old Jun 3, 2005 | 08:07 PM
Default Re: pr3 and pw0 chips interchangeable? (CRXofPain)
anyone?
id appreciate it.
Old Jun 3, 2005 | 08:41 PM
Tbone's Avatar
Wont work from what I'm told.
Old Jun 3, 2005 | 08:43 PM
Default Re: pr3 and pw0 chips interchangeable? (Tbone)
and i specifically asked that mike vong fella to send me a pr3 socket and chip.
twice. makes me kind of mad. anyone know him? he lives in westminster cali (orange county)
Old Jun 3, 2005 | 08:48 PM
Fobtions's Avatar
no that will not work.
tell him to send u a pwo chip. good luck
Old Jun 3, 2005 | 08:59 PM
Default Re: pr3 and pw0 chips interchangeable? (Fobtions)
i have a 28 pin dip socket.
i haev a chip labled "pwo pr3 spoon 4200 vtec no rev limit no speed limit
im about pissed off enough to just go on ghettodyne and buy all my own programming **** and a chip burner and start burning off whatever the hell i want.
can i unsolder the 28 pin stock "chip", solder in my socket, then place the stock chip into the socket that i desoldered from the board until i start making my own ****?
heres the derelict's site. as you can see it says "pr3 pwo pr4 blah blah" all on the same line
http://mvcompany.net/ECUSupport_HOBD0.html
Old Jun 3, 2005 | 09:19 PM
zCivic's Avatar
You can't use a PWO chip in a PR3 but if you'll notice all of the ECU's codes listed are OBD0, it may just be a generic sticker for all of the OBD0 ECU. Turn the ign on but dont start it, once you hear your relay click off your CEL light should go out, if it doesn't then you know the ECU/ROM is bad. If you've never soldered or desoldered be careful not to rip/pull any of the tracers out but if your up and willing to do it, add a Ares ZIF socket or some other low profile ZIF so you can change ROM easily. Good luck... check this site out it helps a ton... PGMFI.org
Old Jun 3, 2005 | 10:30 PM
Default Re: pr3 and pw0 chips interchangeable? (zCivic)
ya ive desoldered. not the best at it but ive got some good desoldering braid. i dunno. this guy makes himself hard to get ahold of too.
90turbointegra
Engine Management and Tuning
Aug 12, 2009 11:20 PM
88cerx
Dec 17, 2005 10:35 AM
stillrockin18s
Jun 28, 2005 05:31 AM
xDicktonesx
Jun 23, 2005 02:24 PM
