Pretty upset...
Ok I did the rear disc brake conversion with the stock teg set up. Everything went on pretty smoothly... after all said and done I take a closer look and my rear driver tire is angled wrong. The top now rubs on my fender which it never did before and the front of the tire is angled slighty in... like it would be turning right if it was moving. Im pretty upset... I had PERFECT camber before the conversion and this is really going to wear my tire. Do you think I got a bent set up or is it an easy fix with bolt adjustments?
Its possible something is bent, but you should get an alignment asap - I wouldnt drive much on it until its done.
If the shop cant align itbecause of bent parts, they'll let you know
I did my rear disc conversion a couple weeks ago and mine turned out the same way, if you don't note exactly where the little slidy bolt on the front of the setup is, then you'll come out with crappy *** toe.
The toe of my wheels were pointing in pretty bad after mine so i just got an alignment and now it's fine.
Don't worry about it I'm sure it's just an alignment issue, don't drive it much until you do that though.
Chris Crane
Nov 12, 2008 07:57 PM
Ex Member
Aug 3, 2006 12:00 PM
eghatchproject
Jan 17, 2004 06:14 PM
