anyone try carbs on a ls
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">Yes, they work fine, as long as you mean Webers or Mikuni's.</TD></TR></TABLE>
what would be the benefit to run carbs over like ITBS on an ALL motor setup. Like Bizi doesnt he run carbs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepey »</TD></TR><TR><TD CLASS="quote">
what would be the benefit to run carbs over like ITBS on an ALL motor setup. Like Bizi doesnt he run carbs?</TD></TR></TABLE>
Better fuel atomization
Unless you run the injectors further outboad, where they are supposed to be. Itb's have less internal flow restrictions than carbs. Theirfore size to size they flow more air.
when you say better fuel atomization this would explain why bisi runs them, if in fact he does because i know for a fact his motor runs 17:1 compression and even the highest octane fuel will hardly even atomize at the high of a CR. but doesnt he run methanol or something like that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXofPain »</TD></TR><TR><TD CLASS="quote">when you say better fuel atomization this would explain why bisi runs them, if in fact he does because i know for a fact his motor runs 17:1 compression and even the highest octane fuel will hardly even atomize at the high of a CR. but doesnt he run methanol or something like that? </TD></TR></TABLE>
I still run gasoline: Rocket brand 118, to be exact. Carbs do offer 2 appealing advantages; excellent atomization and cooling effects (joule-thompson).
The question was " do carbs work" not are they better than ITB's, Stock, Plenums, 2 1200 Holley's, or a Turbo. The answer is YES. And some people make them work better than others. If you got them, run them. There are a few people on here that can give you a base set-up.
NirVTEC
15
May 14, 2007 06:52 PM
slowcrxwannarace
May 4, 2005 12:18 PM
