Door Handles stuck!! HELP!!!
Old Jun 3, 2005 | 08:01 AM
celerilux's Avatar
Default Door Handles stuck!! HELP!!!
On my 92 Honda Civic Hatchback, the door handles on both the driver and passenger side get stuck in the open position (im talking on the outside). I want to know how to gte into the door to fix this problem. Thanks in advance!
Old Jun 3, 2005 | 08:26 AM
snatch's Avatar
Default Re: Door Handles stuck!! HELP!!! (celerilux)
Well if you can open the door, you need to pull the door panel off and check everything with the door opening mechanism. It should all be at the back of the door, leading from where the handle is to where the latch is.
Old Jun 3, 2005 | 07:19 PM
logikalfury's Avatar
get some silicon spray lube, or wd-40 and just spray the joints a bit, this happened on my passenger door, and sprayed it, now over a year and no problems.
Mychal71
Mar 20, 2022 01:32 PM
suhteevin
Jan 6, 2009 09:04 PM
.one lane
Nov 22, 2004 11:09 PM
PatrickGSR94
Feb 10, 2004 03:38 AM
KidMo
Jan 15, 2003 12:06 PM
