Switches near the clutch pedal on 5th gen
Old Jun 3, 2005 | 06:59 AM
K-Spec's Avatar
Default Switches near the clutch pedal on 5th gen
http://www.hondaautomotivepart...3.gif
Does anyone know where #7 and #9 plug into? And what purpose do these switches serve? Doing a swap and need to know.
Thanks guys/gals
Old Jun 3, 2005 | 07:12 AM
K-Spec's Avatar
Default Re: Switches near the clutch pedal on 5th gen (khalal538)
Old Jun 3, 2005 | 07:30 AM
94vtecmn's Avatar
Not sure where they plug into, but most likely the one is for the clutch engagement requirement for the starter, and the other is for the cruise control disengagement when the clutch is depressed.
Old Jun 3, 2005 | 07:31 AM
kulrevon's Avatar
Default Re: Switches near the clutch pedal on 5th gen (94vtecmn)
I second that.
Old Jun 3, 2005 | 07:54 AM
92hondalude's Avatar
Default Re: Switches near the clutch pedal on 5th gen (kulrevon)
i third that
Old Jun 3, 2005 | 08:18 PM
K-Spec's Avatar
thanks for the info guys!
Anyone else here know where the harnesses for these switches are located?
Old Jun 4, 2005 | 08:45 AM
K-Spec's Avatar
anyone else?
Old Jun 4, 2005 | 12:19 PM
Taikonaut's Avatar
Don't mean to steal your thread, but since you already have the picture up
What is the spring on the clutch for? I replaced my master and can't get it back on, is it something I need or can I go with a .00001lb weight reduction
Old Jun 4, 2005 | 02:47 PM
K-Spec's Avatar
Default Re: Switches near the clutch pedal on 5th gen (Taikonaut)
The spring is for the clutch to rebound when you depress it. If you take the spring out...the clutch will be pressed the whole time...and i dont think you want that
Old Jun 4, 2005 | 07:57 PM
Taikonaut's Avatar
Well the clutch still returns after I press it in.
Old Jun 5, 2005 | 09:09 AM
K-Spec's Avatar
can anyone with a 5th gen please take a pic of their clutch area? I need to find out where the harnesses for the switches are located?
Old Jun 5, 2005 | 09:22 AM
98vtec's Avatar
moderator emeritus
i'm pretty sure that one of those switches is the safety switch for having to push in the clutch to crank the car. If you unplug it, you wouldnt have to push in the clutch to start it.
Old Jun 5, 2005 | 06:12 PM
lunarcry's Avatar
Originally Posted by khalal538
Does anyone know where [B
#7[/B] and #9 plug into? And what purpose do these switches serve? Doing a swap and need to know.
Thanks guys/gals
9= clutch switch and 7= clutch interlock switch
9 or the cluch switch hooks to the immobilizer unit plug
what it do? when the clutch pedal is pressed it interrupt the starter cut relay and allow the ignition signal to get to the starter and start the car. the wire it hooks on are the gray wire (do not cut any wire just add a new wire to the circuit). the gray is the positive and the black/gray lines is the negative.
7 or the interlock switch hooks to the cruise control plug
what it do? it interrupt or take the car out off the cruise control when the cluch pedal is pressed, same as the brake do. it hooks to the pink wire of the plug and the black/gray line wire fom the immobilizer plug.
hope that help
Old Jun 6, 2005 | 12:26 AM
K-Spec's Avatar
Default Re: Switches near the clutch pedal on 5th gen (lunarcry)
awesome! you're always very helpful lunarcry
Old Jun 6, 2005 | 04:12 PM
lunarcry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">awesome! you're always very helpful lunarcry </TD></TR></TABLE>
no problem, I will later do a write-up on an auto to manual swap.
cbstd
Jan 31, 2007 05:21 PM
bigj505
Feb 9, 2006 02:12 PM
tylerdurden
Dec 31, 2002 12:08 PM
SH LUDE
Dec 8, 2002 08:42 PM
