? driver headlight problem
Hello everyone, Just completed the JDM B18C swap on a 93 HB. I'd notice that the passenger side driving headlight is brighter than the other. Seems like the current is not equally distributed amonst the bulb. When this happens my left turn signal blinks really fast. Only happens when I turn on the light. The bulbs are fine though. Sometimes it gets bright for a few min. Just wondering if any of you experienced the same issue and if so, what advice can you give. thanks in advance
You say the left turn signal blinks really fast, is this for no reason at all or because you put your blinker. What kind of bulbs are you running? High wattage? Maybe one is going out. Maybe your rear left turn signal is going out? Alternator could be going bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing »</TD></TR><TR><TD CLASS="quote">You say the left turn signal blinks really fast, is this for no reason at all or because you put your blinker. What kind of bulbs are you running? High wattage? Maybe one is going out. Maybe your rear left turn signal is going out? Alternator could be going bad</TD></TR></TABLE>
It blinks really fast when I turn on the blinker. Only when the headlights are on. I am using high voltage bulbs. Could be the alternator. When I press the gas, i do notice that the driver side light does get brighter.
