motor is out.. but problems
Old Feb 8, 2002 | 10:32 AM
[626]95-GSR's Avatar
Default motor is out.. but problems
I finally got my old motor out of my car.. but i ran into a few problems.. as i was lifting the motor out, it didnt clear everything and i hit and cracked that little black charcoal caninster thing on the passenger side firewall side.. i think its where the vacuum line goes, it says 12v on it. the vacuum line is still attached, but i wanna know if this will affect anything. im also having trouble taking that damn shift linkage off, i can see how its done.. but its a biatch. thanks in advance for the help..
Old Feb 8, 2002 | 10:44 AM
RyanR's Avatar
Default Re: motor is out.. but problems ([626]Rj-SiHatchy)
Looks like you've met the infamous bitch pin. If you have one of the bolts that hold the AC compressor to the engine use that to pound it out. If you don't have any of those bolts, use a 8mm punch. Just find the biggest sledge hammer you can find and pound the poo poo out of it.
You'll be find if the charcoal canister is cracked, it's mainly just for emission purposes. But you may want to get a new one otherwise it might start leaking fluid.
Old Feb 8, 2002 | 11:16 AM
AbaZ's Avatar
The charcoal canister isnt really going to affect much, I took mine out years ago, you may smell some minor fuel fumes when your really hauling ***. But I have never smelt anything in mine.
The correct tool to get that out is a 1/4 roll pin punch. get a large hammer and beat that bitoch out.
Jeff Frank
[Modified by AbaZ, 8:18 PM 2/8/2002]
Old Feb 8, 2002 | 12:09 PM
-TJ's Avatar
-TJ
Default Re: motor is out.. but problems (AbaZ)
AbaZ means an 8mm (5/16") pin punch. A 1/4" unit will chew up the inside of the bitch pin as you try to drive it out. Having the right punch makes all the difference....
Old Feb 8, 2002 | 01:23 PM
keithv's Avatar
Default Re: motor is out.. but problems (-TJ)
an exhaust bolt works well when trying to punch out the bitch pin.
Old Feb 8, 2002 | 01:27 PM
cbrman's Avatar
Default Re: motor is out.. but problems (breaka_1_9)
LOL.... Been there done that. That thing really is a beotch to get out and put back in. Have fun, its a pain.... Do what they said, a bolt and whack the pizz out of it.
Steven
Old Feb 8, 2002 | 05:28 PM
CRX-RX's Avatar
Default Re: motor is out.. but problems (cbrman)
Maybe it's just me, but if you're plumbed into the charcoal canister, don't you need it to be in good condition to hold a bit of vacuum?
Old Feb 8, 2002 | 05:29 PM
AbaZ's Avatar
Ya ya.. Thanks TJ.. whatever size fits the crown of the pin. I could remember what exact size it was.. and I have standard size punchs.. But he is correct..
Old Feb 9, 2002 | 11:07 PM
thanks for the advice guys.. ive already got the motor in now.. BUT.. ive run into another damn problem, its like there always has to be something wrong.. well as i was finishing up, i was lowering the car, and low and behold.. the jack is lowered too fast and i ended up cracking my radiator and coolant went everywhere.. poo poo!! almost done too. now i need a new radiator, anyone have an extra for me?!
Old Feb 9, 2002 | 11:16 PM
Blown90hatcH's Avatar
Cool....removal of old D16a shift linkage = blow torch = sawzall
Old Feb 10, 2002 | 05:33 AM
Speed_Ricer99's Avatar
Default Re: motor is out.. but problems (Blown90hatcH)
I broke my radiator and AC line Pulling my motor, but thats ok I was replacing/removing them anyway, so I wasnt very careful.
I didnt disconnect the shift linkage, I worked around it.
JusAccord
Aug 5, 2011 07:20 PM
zeusdavis
Mar 22, 2011 10:16 AM
redovermind
May 3, 2010 09:24 AM
BukakkEK9
Jun 6, 2007 07:05 AM
nk2k2
Oct 1, 2006 01:16 PM
