May be getting a JDM ITR tb and want to know something about the gasket.
Old Jun 3, 2005 | 01:02 AM
ringgold's Avatar
Default May be getting a JDM ITR tb and want to know something about the gasket.
Ok I may be getting a JDM ITR throttle body but ran across a post where someone was having a hard time finding the right tb gasket for it. Does the USDM ITR tb gasket fit the JDM tb? I did a search but didnt find the answer. TIA
Old Jun 3, 2005 | 06:26 AM
IN VTEC's Avatar
Default Re: May be getting a JDM ITR tb and want to know something about the gasket. (ringgold)
I don't see why not. I used a USDM gasket for my JDM ITR throttle body. Both of them don't have FITV's and the only difference is that the JDM ITR one has an EVAP purge port, which isn't even a part of the gasket.
Old Jun 3, 2005 | 08:52 AM
ringgold's Avatar
Default Re: May be getting a JDM ITR tb and want to know something about the gasket. (IN VTEC)
Cool I already have a ITR tb gasket so that is one less thing that I would have to buy. My JDM GSR tb has that same port on the top and I just put a plug on it no problems with that.
Old Jun 3, 2005 | 02:01 PM
Comp97GSR's Avatar
The USDM ITR gasket I bought for my JDM t/b did not completely seal the bottom of the t/b. I ended up just making my own using a template of my GSR t/b and modifying it slightly. You can get the material to cut your own gaskets at most auto parts stores. If you do find a USDM gasket that works, post that shiz up.
Old Jun 3, 2005 | 02:03 PM
SecretAgent's Avatar
i used a 99-00 Si OEM TB gasket and it worked perfectly.
Old Jun 4, 2005 | 09:27 PM
ringgold's Avatar
Default Re: (SecretAgent)
Thanks dudes
DeCoY
Aug 25, 2011 09:05 PM
autoxthis
Jul 25, 2008 09:34 PM
emooheo
Aug 4, 2007 09:39 PM
blackoutcivic
May 10, 2006 04:08 PM
Comp97GSR
Aug 22, 2002 05:55 PM
