To tune or not to tune?
Hey everyone whats up I own a 99 Honda Civic EX with a USDM OBD1 B18C1 inside. Now my ? is I just recently "had" to have my head/block rebuilt also had to replace somethings. My current set-up will be JDM ITR pistons/rings skunk2 valves ITR retainers and springs Apexi Header/Apexi Exhaust/AEM intake.. I also have a bore making my comp 11.1.... My ? is should I get tunned and if so how should I have it done? I know when the comp gets up there that there is a chance of detinating but I dont think i'm that high I just want my motor to be tuned so its safe and will run strong
PLEASE HELP ME THANK YOU!!!
DEFINITELY get it tuned. i recommend doing it even on stock motors.
st00pid tuned my stock B18C R (96spec) to 172whp on Neptune. same as what guys are making with I/H/E on the same motor.
I recommend Neptune or Hondata.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SecretAgent »</TD></TR><TR><TD CLASS="quote">DEFINITELY get it tuned. i recommend doing it even on stock motors.
I recommend Neptune or Hondata. </TD></TR></TABLE>
Every setup is different. Its always a good idea to tune your setup to try and maximize your results.
I have seen plenty of setups make extremely simular power tuned vs 1st run on a basemap or chipped ecu.
Btw, 172 whp ? What kind of dyno.
Most of the Jdm R motors I tune on dynojets make 179-183 whp and 129 tq with i/h/e
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">
It was done on a Dynojet 224x, i think with an SAE correction of 1.04. I've seen most 98spec motors make that much, but not too often do you see a 96spec do as well. (i have a 96spec
We only gained 9whp over stock peak, but picked up over 24tq and 15hp from 2400rpm to 4500rpm. I'm also getting better gas mileage, running smoother, and less pinging.
</TD></TR></TABLE>It was done on a Dynojet 224x, i think with an SAE correction of 1.04. I've seen most 98spec motors make that much, but not too often do you see a 96spec do as well. (i have a 96spec
)We only gained 9whp over stock peak, but picked up over 24tq and 15hp from 2400rpm to 4500rpm. I'm also getting better gas mileage, running smoother, and less pinging.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c1Nick »</TD></TR><TR><TD CLASS="quote">What do I need to be able to tune my car? I have never ever had my car tunned.</TD></TR></TABLE>
An obd1 ecu chipped & socketed....
Contact Jeff Evans if your in Pa via http://www.boosted-hybrid.com
Concerning chipped ecus, check out http://phearable.net
Concerning a guide to how tuning works etc, check out: http://www.phearable.net/tech/....html
If you get a obd 1 ecu and conversion harness and tune through Hondata or Crome or Neptune or Uberdata you will get the best tune. But if u wanna pass emmisions you will either have to swap back to obd 2 at emmissions time or tune with a VAFC..... Correct me if i'm wrong on this one
B18C1NMotion
12
Oct 17, 2007 09:54 AM
