F22 to H23 swap in accord STOP!!!
Old Jun 2, 2005 | 09:38 PM
Midnightrayne's Avatar
Default F22 to H23 swap in accord STOP!!!
This last weekend a friend talked me into swapping a f22 for a h23 he said it was a direct swap everything fit.
NO it didnt
The engine fits fine but you need alot of the parts off the H23 that he didnt have
Distbutor H23
driver side engine mount H23
Power steering mount and power steering H23
ECU H23
H23 intake manifold ( the F22 fits but the holes in the H23 are ALOT BIGGER
Throttle cable custom bracket
F22 harness must be switched to H23 for the distributer
Anyways it was a pain in the butt
I here that the H22 is an easier swap, so anyone thinking about doing this swap please for your own sake do your homework!
Old Jun 3, 2005 | 05:30 AM
Turbowa's Avatar
Default Re: F22 to H23 swap in accord STOP!!! (Midnightrayne)
H22 will be basiclly the same. All that stuff should have come with the motor any way.
Old Jun 3, 2005 | 06:27 AM
SpeedFreak77's Avatar
Sounds like your friend needs to read up a bit. A quick search here and you could have found that out in a few seconds before you even did the swap.
Anyway hope things worked out for you.
Old Jun 3, 2005 | 08:43 AM
Vt4kpwn35's Avatar
Default Re: F22 to H23 swap in accord STOP!!! (SpeedFreak77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedFreak77 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your friend needs to read up a bit. A quick search here and you could have found that out in a few seconds before you even did the swap.
Anyway hope things worked out for you.</TD></TR></TABLE>
Sounds like he should have read up a bit before making the swap
lowacc97
Feb 6, 2012 03:12 AM
Smallboxx
Feb 12, 2011 06:55 PM
5thgenludez4life
Sep 19, 2008 08:47 AM
