Si tranny swap?
Old Jun 2, 2005 | 06:38 PM
carracr625's Avatar
Default Si tranny swap?
I own a '91 civic hatch std. Which, of course has a 4spd tranny. I have read that if I swap in a B-series motor, I will have to swap spindles/hubs from an Si. So does this also mean if I just want to run a D-series motor with an Si tranny, that I will have to swap spindles/hubs?
Old Jun 2, 2005 | 06:41 PM
kulangot's Avatar
Default Re: Si tranny swap? (carracr625)
no...if you do a D swap, you can just use your axles..
Old Jun 2, 2005 | 06:42 PM
hatchinprogress's Avatar
if you wanna swap in a si tranny instead of the 4 speed...its just a direct swap(nothin else needed) if you had a hf model the you need to chage the spindles/hubs
Old Jun 2, 2005 | 06:44 PM
kulangot's Avatar
Default Re: Si tranny swap? (hatchinprogress)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">if you wanna swap in a si tranny instead of the 4 speed...its just a direct swap(nothin else needed) if you had a hf model the you need to chage the spindles/hubs </TD></TR></TABLE>
not true...
Old Jun 2, 2005 | 06:49 PM
carracr625's Avatar
Default Re: Si tranny swap? (sirq2u)
So I can just buy new std axles and they will mate up to the si tranny?
Old Jun 2, 2005 | 06:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirq2u &raquo;</TD></TR><TR><TD CLASS="quote">
not true... </TD></TR></TABLE> really?? i thought those were the only "odd" d-series
Old Jun 2, 2005 | 07:01 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carracr625 &raquo;</TD></TR><TR><TD CLASS="quote">So I can just buy new std axles and they will mate up to the si tranny?</TD></TR></TABLE>
yes
Old Jun 2, 2005 | 07:35 PM
carracr625's Avatar
Default Re: Si tranny swap? (jlicrx)
Thanks for the help fellas.
Old Jun 2, 2005 | 08:39 PM
eyesniper's Avatar
and just and fyi
trannys differ by years by the shaft that plugs into the engine i really cant remeber but i thing the 89-91 have the same amount of teeth the 90-91 have two rings where the 89 has one and the 88 and under have less or more teeth i cant remeber and have no ring
Old Jun 3, 2005 | 07:47 PM
carracr625's Avatar
Default Re: (eyesniper)
Thanks again
Old Jun 8, 2005 | 03:41 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (carracr625)
for the search engine, d16a6 tranny transmission swap axles axle hub knuckle
sorry i had to do this.. i finally found this page after searching for a while and some of the terms i used were not found. but this should make it easier. and i guess this serves as a verification bump also. if youve done it, let us know it works. thanks guys.
Old Jun 8, 2005 | 08:35 PM
NastyHabitzCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eyesniper &raquo;</TD></TR><TR><TD CLASS="quote">and just and fyi
</TD></TR></TABLE>no, the 88 has a diffrent spline count than the 89-91.
pinecone
May 20, 2006 11:02 AM
norm13
Jan 23, 2006 03:22 PM
ShiftSpeed
11
Feb 23, 2005 11:19 AM
JStone2775
Aug 20, 2002 11:16 AM
95gsr
May 30, 2002 11:54 AM
