ABS- How would you know if you have it or not?
The quickest? Slam on your brakes really hard. If your car shudders and doesn't stop right away and you feel your pedal vibrate slightly you have ABS. Also works in snow/water. Most sensable? Your user manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRCivic97 »</TD></TR><TR><TD CLASS="quote">The quickest? Slam on your brakes really hard. If your car shudders and doesn't stop right away and you feel your pedal vibrate slightly you have ABS. Also works in snow/water. Most sensable? Your user manual.</TD></TR></TABLE>
Yeah that would be easy, but Im too lazy to walk out to the car.
U aint gonna be able to check ABS sittin in ur home lol. Might as well take a lil ride and do what sr civic said or if u have ABS light like what hitem'up said just got outside and turn the ignition. It dont take but two fingers and a turn.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAiL05 »</TD></TR><TR><TD CLASS="quote">U aint gonna be able to check ABS sittin in ur home lol. Might as well take a lil ride and do what sr civic said or if u have ABS light like what hitem'up said just got outside and turn the ignition. It dont take but two fingers and a turn.</TD></TR></TABLE>
I dont have ABS, no light and no hydraulic pump.
Look at the proportioning valve on the firewall. If there's only 4 lines coming in/out of it, you have ABS, if there is 6, you don't. Or you could look for the big *** control module in the engine bay, or the second fuse box in the engine bay as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HitEm’Up »</TD></TR><TR><TD CLASS="quote">Or turn your key to the ON position and a light should appear
yeap, ALL abs cars, regardless of make and model, wil have an ABS light that illuminates like the CEL when you switch your car to the on position
</TD></TR></TABLE>yeap, ALL abs cars, regardless of make and model, wil have an ABS light that illuminates like the CEL when you switch your car to the on position
