Mini me tuning
Old Jun 2, 2005 | 12:34 PM
shbrown's Avatar
Default Mini me tuning
I am just getting my mini up and going... I have a couple of tuning questions... If the cam mark will not line up with the crank marks, do I have to get a new adj. cam pully? It always seems to be a half tooth off. Some searches say no big deal, but I am not sure...
And fuel pressure... Does the ECU assume a given fuel pressure, and moderate injector's inject time based on this? From this, should I assume if I use a D16Z6 fuel map, I need to have the fuel pressure at Z6, not A6 levels? (Z6 FPR)
Also, I want to chip my PM6, hopefully with Z6 maps and vtec output. Who can do this?
-Simon
Old Jun 3, 2005 | 08:40 AM
91backslash's Avatar
i also would like to know this??
Old Jun 3, 2005 | 08:50 AM
user 98292739's Avatar
you are suppose to use the z6 FPR...at least in most places i read.
Old Jun 3, 2005 | 09:22 AM
shbrown's Avatar
Thats is what I have read to. Sounds like you get ~10psi more with the Z6 FPR.
With the A6 FPR I will be running lean?
If I am still running a stock pm6 ECU, should I switch FPR to Z6?
If I get Z6 maps chipped in, then I would need to switch for sure to Z6 FPR?
And where is a good place to get a FPR?
Thanks!
Thanks!
Old Jun 3, 2005 | 09:42 AM
Redline130's Avatar
Default Re: Mini me tuning (shbrown)
What bottom end did you use? If it's a 1.5L bottom, then you will need an adjustable cam gear if you don't want to have your timing half a tooth off.
Old Jun 3, 2005 | 10:13 AM
shbrown's Avatar
I've got the A6 1.6L bottom end. It looks like the timing is a half tooth off. I got the head resurfaced, maybe that did it?
Old Jun 3, 2005 | 10:59 AM
Redline130's Avatar
Default Re: (shbrown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shbrown &raquo;</TD></TR><TR><TD CLASS="quote">I've got the A6 1.6L bottom end. It looks like the timing is a half tooth off. I got the head resurfaced, maybe that did it?</TD></TR></TABLE>
Quite possibly, depends how much you shaved off the head.
Old Jun 3, 2005 | 12:05 PM
i have the a6 and it lines up perfectly...at least i think car runs like its on roids now though after the swap w. this custom mini me map for higher compressoin
Old Jun 3, 2005 | 08:19 PM
i shaved the block .020 and it lines up perfect.
Old Jun 4, 2005 | 01:15 PM
yea my head was shaved not sure how much bought it that way...but it was enough for me to have to file down the rods quite a bit for it to sit flush.
Ax3l
Oct 11, 2005 10:48 PM
jonleeone
Jun 23, 2005 02:20 PM
shbrown
Jun 10, 2005 02:29 PM
onePOINTsix
Aug 26, 2003 12:58 PM
crx(gator)
Jul 21, 2002 07:57 PM
