Ground Control pics
Hey guys, I just got my ground control coilovers and I wanted to show you guys just to make sure I have everything. I wanted to see if I have the sleeve part which makes it compatible with the KONIs, I ordered them specifically with the KONIs however I just want to make 100% sure. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808_si »</TD></TR><TR><TD CLASS="quote">what spring rates did you get?</TD></TR></TABLE>
It says it right on the springs... (sheesh)...
they ARE kinda blurry. i think its 450/300.
just more proof that ground control kits will actually provide different spring rates for different cars, default.
unlike OmTHER2 companies that provide the same 2 damn springs for every car...
The box has 98 Accord marked off on it since 98-02 are all 6th gens does it matter that it says 98 Accord and that I have an 01? The other choices are 90-97 Accord and some TL years, so I'm guessing it's alright since 90-97 are all 5th gen accords, correct? When I ordered I was given a choice of street, autox/street, and full out race. I picked street since my area is rather bumpy on some roads and it would just cause my ride to be unpleasant.
Modified by Corruption at 9:05 AM 6/3/2005
I'm so paranoid that I don't have the right parts for the KONIs/GC coilovers to be compatible. I looked at the box once again and it was 98-02
, so that's alright. I bought the KONIs/GCs from shox.com and I got the package so they were compatible but I just want to make sure I have the parts for them to be, does anyone have the pictures of the stuff to make them both compatible? thanks
Mine came with bumpstops...on the directions it'll tell you to cut them to a certain size depending on if you have konis or gcs. I believe it just keeps them from bottoming out.
I guess I should just cut the stock bump stops in half it says, I'm trying to find the clip that keeps the GC's in place towards the bottom of the KONI's, however I think it may be built in...hmmm
Modified by Corruption at 10:43 AM 6/4/2005
there should be a black ring thing on the bottom of your gc sleeves..can't really tell from the pics but just check if you have them
the koni shocks will have the circlip that the black ring thing rests on
not sure if either company is supposed to provide you with new bumpstops but you can just use your old ones
if 98-02 are all 6th gen accords then you're fine
Ya...I forgot...mine also came with different sized black o-rings that you put on the struts and slide the sleaves over them to hold the sleave in place. I had agxs so I don't have a clue about the konis.
No that is not the ring. The ring should pressed inside the threaded metal sleeves. I can see on the side view in your pic that they are their, and they have the proper groove to acept the circlip.
As for bumpstops, I've never seen any shocks or GC springs come with them ever...
No worries mate, your good to go... (be brave)...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg64u »</TD></TR><TR><TD CLASS="quote">performance is bomb with your setup but get ready to ride on bricks.</TD></TR></TABLE>
even if you get softer spring rates?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">quit yapping and install. You have everything....</TD></TR></TABLE>
Seriously. I put my suspension in yesterday and it only took 2.5 hours with basic hand tools (no air).
shut up
, jk, thanks guys and the konis have a little clip towards the end of the shock to keep the coilover from coming down, it's like a little box that extends out? i can show you guys through pictures if you want
...im going to a place tomorrow concerning installation
