A\C Condenser not turning on, but fan comes on?
Old Jun 2, 2005 | 11:35 AM
Totalpkg's Avatar
Default A\C Condenser not turning on, but fan comes on?
A\C Condenser not turning on, but fan comes on? System was just recharged and tech says conderser is not turning on. Any help? its a 99 Civic si.
Modified by Totalpkg at 12:56 PM 6/2/2005
Old Jun 2, 2005 | 08:06 PM
Totalpkg's Avatar
Default Re: A\C Condenser not turning on, but fan comes on? (Totalpkg)
Anyone?
Old Jun 4, 2005 | 10:12 PM
Qfactor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Totalpkg &raquo;</TD></TR><TR><TD CLASS="quote">A\C Condenser not turning.Modified by Totalpkg at 12:56 PM 6/2/2005</TD></TR></TABLE>
holy $hit!!!! WTF....I would stay far far away from that crack head tech. a condenser unit does not have any moving parts,let alone one that uses a voltage source. it's purpose is to absorb the cooler atmospheric air (heath transfer).
Old Jun 5, 2005 | 04:43 AM
non-VTEC's Avatar
Default Re: A\C Condenser not turning on, but fan comes on? (Qfactor)
he probably misunderstood the tech.
the compressor is not turning on.......sounds like the system is low on refrigerant. or you have a electrical problem with the A/C system.
Old Jun 5, 2005 | 05:28 AM
rainforest's Avatar
Default Re: A\C Condenser not turning on, but fan comes on? (non-VTEC)
usuall a field coil. they are about 60bucks or a leak causing low refridgerant, wich wont let the compressor cycle
Old Jun 5, 2005 | 01:07 PM
PrettyLude's Avatar
also check for loose connections going to the compressor itself
Old Jun 10, 2005 | 10:51 AM
Totalpkg's Avatar
Thanks to all. I figured out the a\c clutch fan was not running. I check all connections as per Helms manual and all were good. So I plugged the stock ECU in and I had a\c. But with the chipped P28 no a\c! I had a p28 plugged in with a harness conversion. The pin out for the a\c clutch fan was in the wrong pin out. (a17 instead of a15) I swapped them and voila a\c. Thankx to all
knotcher
Jun 29, 2015 10:34 AM
94_civicEx
Honda Civic (2006 - 2015)
Jun 13, 2014 12:28 AM
94LS_allmota
Jul 24, 2009 06:06 PM
stockEJ
Aug 6, 2008 06:46 PM
crxsi8
Aug 22, 2005 05:41 PM
