headunit upgrade?
True, once you start you'll have to end up replacing speakers as well, which is another $200 if you're lucky. If you listen to music with any seriousness it's worth it though.
My advice on a head unit is get something quality that's laid out simple and clean so you don't have to screw with it for minutes on the freeway trying to switch to FM or something. Check out Eclipse units if you can.
Dan
Dan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kX »</TD></TR><TR><TD CLASS="quote">is it worth it to upgrade my stock stereo system. i bump it up occasionally. im interedted in the piooneer though</TD></TR></TABLE>In a word, YES, you will be surprised at how good your stock speakers sound once you get a little power to drive them, that said, replacing speakers is also a good idea, but replacing speakers before you replace the HU is pointless I think, and makes very little diff. in SQ, the speakers only reproduce what the HU puts out, and when you do upgrade the speakers, and you will, do the fronts first.
94
94
I have an Eclipse CD8443. Remember, Eclipse doesn't have detachable faceplates, and they won't honor anything that's supposed to go with the headunits unless you have it installed by an Eclipse dealer.
Mr.AngryClown
Audio / Security / Video
Sep 28, 2004 12:52 PM
TypeR1558
61
Sep 28, 2002 10:15 AM
