'02 accord EXV6 front turn signal bulb change. WTF?
From my initial inspection, the only way I can see to get to the bulbs is by removing the bumber cover and then removing the headlight assembly.
Am I being stupid here?
I know what kind of bulb it is and I'm quite automotively inclined, I just don't see any other way to get to that bulb. I would hope that honda wouldn't engineer something like that.
Any help is mucho appreciated.
I have 00 accord..the only way you can do that is to remove the inner fender liner, or at least the 1st of the liner...find the bulb and twist it off...you be doin hella a lot of work if you remove the bumper. Thats what i did...good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aboysav6 »</TD></TR><TR><TD CLASS="quote">I have 00 accord..the only way you can do that is to remove the inner fender liner, or at least the 1st of the liner...find the bulb and twist it off...</TD></TR></TABLE>
That's how I do em too. They're a pain to get to.
Well, I did it by taking off the bumper cover. It wasn't as difficult as I expected, just a few of those plastic rivets and 4 machine screws. I went ahead and removed the headlights on both sides and replaced all the bulbs with the sylvania silverstars. Wow, these bulbs kick ***. Amazing how freaking bright they are.
blue_misfit
Dec 4, 2007 09:52 AM
trimagna
Aug 31, 2007 07:23 PM
ef_you_again
Apr 10, 2005 12:57 PM
