fuel pump/pressure on b18c
Old Jun 1, 2005 | 09:34 PM
iNERtIA's Avatar
Default fuel pump/pressure on b18c
i have a b18c on my ek, running on oem civic fuel pump. would i need to change it to an integra pump or will my civic pump work fine,
the reason i ask is because everytime my fuel is down to about 1/4 tank, it will run very crappy, so im guessing my fuel pressure is low. i checked my fuel pressure at idle it seemed to be fine at 40psi.
will the integra pump bolt on directly on my ek and is there any difference between civic and intgra pump? also could i just use an adj.FPR instead of replacing my pump?
thanx
Old Jun 1, 2005 | 11:09 PM
Humble1's Avatar
Default Re: fuel pump/pressure on b18c (tEaM-IneRtia)
i have a 95 civic coupe with b18c. im running the stock civic fuel pump and have no problem whatsoever
Old Jun 1, 2005 | 11:30 PM
stevenlo's Avatar
replace it with a bigger one man, then get a turbo...lol...jk man the civic one should be fine, but if you want a lil more umph to push the motor, get the gsr one it will fit, but no the bracket though! good luck yO!
Old Jun 2, 2005 | 02:12 AM
sinister6's Avatar
Im running 200WHP on a B18CR in a EK hatchy, using stock DX pump no problem slam it WOT in every gear.. oh ive got 440cc injectors too.
but then i was thinking go for a Walbro 255LHP
Old Jun 2, 2005 | 09:13 PM
iNERtIA's Avatar
is it pretty easy to swap in the gsr one or is it gonna be a pain to put it on? my buddys running on stock pump on his h22 eg w/o probs too. maybe mines just starting to die out.
thanx guys!
Old Jun 2, 2005 | 09:17 PM
Luserkid's Avatar
Default Re: (tEaM-IneRtia)
I made 210whp turboed on my stock DX pump. Maxed it out so i upgraded.
fakesmi1e
Aug 21, 2017 05:53 AM
SPOONfdEK
Jun 2, 2003 01:01 AM
Andrew 825SM
Nov 17, 2002 01:42 AM
evil_elmo
Jul 17, 2002 04:35 PM
