disk and drum, is the e brake cable different?
Old Jun 1, 2005 | 08:17 PM
crx_of_fury's Avatar
Default disk and drum, is the e brake cable different?
just like it says, is there a difference in cables?
Old Jun 1, 2005 | 08:26 PM
Default Re: disk and drum, is the e brake cable different? (crx_of_fury)
does anybody know
Old Jun 1, 2005 | 08:32 PM
Mach69's Avatar
if you are converting from drum to disk, you will need a different e-brake cable, yes.
If you have a crx and want to convert from drum to disk, buy '90 to '91 CRX si ebrake cables
If you have a civic hatchback, buy the '92 Integra GSR ebrake cables if you want discs in the hatchback.
Old Jun 1, 2005 | 08:34 PM
Default Re: disk and drum, is the e brake cable different? (Mach69)
i have disk brakes but my ebrake doesn't work and i have a dx parts car with a working e brake and want to know if it would fit
Old Jun 1, 2005 | 09:56 PM
Mach69's Avatar
A drum ebrake will not fit onto a disc ebrake. You will need to find a different ebrake cable, preferably one form a disk'ed car.
Old Jun 2, 2005 | 12:16 AM
abnaasefmb's Avatar
i used 95 abs discs from a teg and every thing bolted up. i have done two of these swaps. be sure to use the teg port valve and it helps to use a ef ex master cyl aswell. not to be an *** but do a search cuz lots has been written about this.
shackler
Mar 8, 2007 04:26 PM
CRX 2.0V-T
Jan 8, 2007 12:17 AM
ef u
Sep 24, 2005 08:19 PM
PROJECTEF9
Aug 3, 2003 06:56 PM
