Townsend Bros. H2B Adapter Plate... Its 6/1/05 are you shipping product????
Old Jun 1, 2005 | 07:01 PM
DDD's Avatar
DDD
Default Townsend Bros. H2B Adapter Plate... Its 6/1/05 are you shipping product????
I just figured I would start a thread in referance to an email that Seth Townsend (Bserious) responed too. I and I'm sure many others are interested in the availabilty, quality, and overal performance of this suposed kit. So for those of you that are ordering, plan on ordering, or have any prior dealings (good or bad) w/ Quartersports Drag Products, Seth Townsend, and/or the H2B kit please post your experiences.
OK on w/ the emailed response (I am leaving out the quoted prices. I dont want involed in the BS) ...
"All kits will be available June 1st, 2005. This response should answer the majority of the questions everyone has asked.
Our H2BTM kit allows you to combine an H-series engine with complete manual B-series drive train. You retain the use of the B-series flywheel, clutch, starter, intermediate axle, axles, and shift linkage making the installation very simple.
The core of the kit is a 6061 aluminum CNC adapter plate that secures the engine and transmission together. The engine adapter plate works in conjunction with a flywheel spacer, intermediate axle mount, an engine mount adapter, and custom fasteners.
A few essential modifications are required in all of the kits. You must shave the rear of your H-series block to create clearance for the B-series intermediate axle. Your frame rail must be notched to clear your OEM pulley system. OEM Hood clearance also becomes minimal and will require you to space the rear hinges 1.5 inches.
Each model kit requires a specific OEM engine mount. The 1996-2001 Civic and the 1990-1993 Integra kits use the OEM chassis engine mount. The 1992-1995 Civic and 1994-up Integra kits use a 1994-up GSR engine mount. The 1988-91 Civic/CRX kits require the use of either your bolt-in-kit engine mount or an OEM 1990-1993 Integra engine mount, but with more depth in fabrication.
There are numerous bolt-in-kits for the 88-91 Civic/CRX chassis, each varying the B series location. Our solution is to supply the 88-91 kits with a driver’s side engine mount, oversized and un-fabricated, which will require cutting and welding to match your application.
The 1988-1991 Civic/CRX’s and 1990-1993 Integra front crossmembers must also be replaced with aftermarket pieces to relocate the radius rods. We will also have these available.
The pricing is as follows:
QS004 1996-up Honda Civic [EK] Kit $xxx
QS003 1992-1995 Honda Civic [EG] Kit $xxx
QS003 1994-up Acura Integra [DC] Kit $xxx
QS002 1990-1993 Acura Integra [DA] Kit $xxx
QS001 1988-1991 Honda Civic/CRX [EF] Kit $xxx
Please feel free to email me back if I have still not answered all of your questions. Also check out our website at http://www.quartersportsdrag.com. We will have a page up shortly detailing the installation.
Thank you for your inquires,
Seth Townsend"
Old Jun 1, 2005 | 08:09 PM
AdamBOMB_STi's Avatar
Default Re: Townsend Bros. H2B Adapter Plate... Its 6/1/05 are you shipping product???? (DDD)
i just got off the phone with seth and he said all of the kits were sold by 3pm today. he is working on getting the second batch out by end of next week, but he says not to worry as he do his best to make the kits as readily available asap. I am also waiting on a kit, but funds need to come in first. hope this helps out.
Old Jun 2, 2005 | 03:40 PM
Bserious's Avatar
Default Re: Townsend Bros. H2B Adapter Plate... Its 6/1/05 are you shipping product???? (DC_2.2)
That is correct. The second batch will be completed by the 12th.
If what's posted above doesn't answer all of you questions feel free to email me.
This coming Battle in Fontana should have a few racers sporting the kits.
Old Jun 2, 2005 | 03:44 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Townsend Bros. H2B Adapter Plate... Its 6/1/05 are you shipping product???? (Bserious)
Looks good
Old Jun 2, 2005 | 04:30 PM
Bserious's Avatar
Default Re: Townsend Bros. H2B Adapter Plate... Its 6/1/05 are you shipping product???? (PURPLETERROR)
Yeah, everything but those valve marks on the pistons.
Old Jun 4, 2005 | 07:04 AM
DDD's Avatar
DDD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserious &raquo;</TD></TR><TR><TD CLASS="quote">That is correct. The second batch will be completed by the 12th.
Glad to hear. There are just to many companies that always make claims and promisses about inovating products and never come through. to you guys for making it happen.
Old Jun 4, 2005 | 08:20 AM
Stunna BEN's Avatar
Don't call it a comeback
Old Jun 4, 2005 | 08:57 AM
JCushing's Avatar
does it shift the engine over or does it shift the tranny over.
Old Jun 5, 2005 | 08:17 AM
DDD's Avatar
DDD
Default Re: Townsend Bros. H2B Adapter Plate... Its 6/1/05 are you shipping product???? (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">does it shift the engine over or does it shift the tranny over.</TD></TR></TABLE>
Transimission stays in origonal location and posistion using all the OE or mount kit (Hasport, Avid, etc.) mounts.
Old Jun 5, 2005 | 09:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserious &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, everything but those valve marks on the pistons.</TD></TR></TABLE>
I thought those were horsepower reliefs
Old Jun 5, 2005 | 10:18 AM
Adam.'s Avatar
Pricing?? Can you pm me with the pricing for 92-95 civic.
Old Jun 5, 2005 | 10:35 AM
HavokB18's Avatar
So if we are using a Hasport mount kit in an EG we are good to go? Or do we have to purchase a different motor mount setup?
Old Jun 5, 2005 | 11:35 AM
Bserious's Avatar
Default Re: (HavokB18)
Yes, you can retain the use of your mount kit, or go back to OEM.
Old Jun 19, 2005 | 05:19 PM
Hatch-E's Avatar
pm me with a price for a 92-95 kit plz. TIA!
Old Jun 19, 2005 | 06:10 PM
884drb16's Avatar
Default Re: (Bserious)
pm with a price 4 88-91
Old Jun 19, 2005 | 07:29 PM
Bserious's Avatar
Default Re: (884drb16)
All IM responded up to this point....
Old Jun 20, 2005 | 05:07 AM
Stunna BEN's Avatar
Bump
Old Jun 23, 2005 | 10:49 PM
soon2brb240's Avatar
My turbo stuff is as good as sold, thanks to you guys! I'll be looking for a 90-93 integra kit soon...
Old Jun 24, 2005 | 10:55 AM
skunked's Avatar
Default Re: (soon2brb240)
up for Seth & Zac
Goodluck at CMI
Old Jun 24, 2005 | 05:36 PM
fastcivic416's Avatar
can you pm me a price for this kit into an EK sedan? also please include the shipping price to toronto, canada. thanks!!
Old Jun 27, 2005 | 06:22 AM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserious &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you can retain the use of your mount kit, or go back to OEM. </TD></TR></TABLE>
So if I understand this correctly I can use standard b-series mounts for the h22 w/ b-series tranny?
Makes it a little easier to swallow the price of the kit and new tranny if I can sell my $500+ mount kit and $1000 transmission.
Old Jun 27, 2005 | 09:32 AM
SuicideSlide's Avatar
Default Re: (DarkKnight1)
So is this a bolt in product or do you ned access to a welder for it to work. I see it states welding on your crx's/ef's. What about the EG's and EK's?
Old Jun 27, 2005 | 10:01 AM
FLoSSnJERKS's Avatar
Default Re: (TurbLu)
Old Jun 27, 2005 | 12:53 PM
Blind-Fashion's Avatar
Old Jun 28, 2005 | 06:37 PM
Bserious's Avatar
Default Re: (Blind Fashion)
EF's require welding.... Why you ask?... Because of all the numerous bolt-in-kits on the market. Our goal was to make a kit available to ALL EF owners, not just owners of one particular kit.
The EG, EK, DC, and DC kits are all pre-fabricated (no welding).
