few questions before i build..
im assuming since a b20 is a b series i can use a b16 aftermarket flywheel and clutch correct?
where will i be compression wise with a stock b20 shortblock mated to a built p30 b16 head with flat faced valves?
when i have more questions ill ask in this thread..thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip »</TD></TR><TR><TD CLASS="quote">im assuming since a b20 is a b series i can use a b16 aftermarket flywheel and clutch correct?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip »</TD></TR><TR><TD CLASS="quote">where will i be compression wise with a stock b20 shortblock mated to a built p30 b16 head with flat faced valves?</TD></TR></TABLE>
Not very high. Plus if you use anything bigger than the stock B16 cams you may want to worry about valve clearance issues.
Yes.
hmmm...i just found a thread created by sparkracing.com and they sell block packages prebuilt..i was looking at the #2 N/A package..ls block with 11.5:1 cr arias pistons and all new everything else assembled for $1500.00..would this be a better route?..is sparkracing.com any good..is there somewhere else i can go thats reliable to buy a similar package for about the same price or cheaper?..im looking to spend about 1000-1500 on a block for either ls/vtec or b20/vtec..thanks
edit:..heres the link i was looking at...all sleeves are done by rs machines..im looking at package #2 N/A...any thoughts about the package or sparkracing.com?..are they reliable people to deal with?..i would honestly rather buy a block thats assembled rather than try and build one...thanks again
https://honda-tech.com/zerothread?id=1189655
